Automatic Tongue Delineation from MRI Images with a Convolutional Neural Network Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Artificial Intelligence Année : 2020
Tongue contour extraction from real-time magnetic resonance images is a nontrivial task due to the presence of artifacts manifesting in form of blurring or ghostly contours. In this work, we present results of automatic tongue delineation achieved by means of U-Net auto-encoder convolutional neural network. We present both intra- and inter-subject validation. We used real-time magnetic resonance images and manually annotated 1-pixel wide contours as inputs. Predicted probability maps were post-processed in order to obtain 1-pixel wide tongue contours. The results are very good and slightly outperform published results on automatic tongue segmentation.
Fichier non déposé
hal-02962336 , version 1 (09-10-2020)
Karyna Isaieva, Yves Laprie, Nicolas Turpault, Alexis Houssard, Jacques Felblinger, et al.. Automatic Tongue Delineation from MRI Images with a Convolutional Neural Network Approach. Applied Artificial Intelligence, 2020, 34 (14), pp.1115-1123. ⟨10.1080/08839514.2020.1824090⟩. ⟨hal-02962336⟩
189 Consultations
0 Téléchargements
