New interface
Journal articles
Splitting models for multivariate count data
Abstract : We investigate the class of splitting distributions as the composition of a singular multivariate distribution and a univariate distribution. It will be shown that most common parametric count distributions (multinomial, negative multinomial, multivariate hypergeometric, multivariate negative hypergeometric, …) can be written as splitting distributions with separate parameters for both components, thus facilitating their interpretation, inference, the study of their probabilistic characteristics and their extensions to regression models. We highlight many probabilistic properties deriving from the compound aspect of splitting distributions and their underlying algebraic properties. Parameter inference and model selection are thus reduced to two separate problems, preserving time and space complexity of the base models. Based on this principle, we introduce several new distributions. In the case of multinomial splitting distributions, conditional independence and asymptotic normality properties for estimators are obtained. Mixtures of splitting regression models are used on a mango tree dataset in order to analyze the patchiness.
Document type :
Journal articles
Complete list of metadata
Cited literature [55 references]  Display  Hide  Download
https://hal.inria.fr/hal-02962877
Contributor : Jean-Baptiste Durand Connect in order to contact the contributor
Submitted on : Friday, October 9, 2020 - 3:30:11 PM
Last modification on : Friday, August 5, 2022 - 10:51:49 AM
Long-term archiving on: : Sunday, January 10, 2021 - 6:50:16 PM
File
main.pdf
Identifiers
Citation
Jean Peyhardi, Pierre Fernique, Jean-Baptiste Durand. Splitting models for multivariate count data. Journal of Multivariate Analysis, 2021, 181, pp.104677. ⟨10.1016/j.jmva.2020.104677⟩. ⟨hal-02962877⟩
Share
Metrics
Record views
114
Files downloads
241
