Asteroid: the PyTorch-based audio source separation toolkit for researchers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper describes Asteroid, the PyTorch-based audio source separation toolkit for researchers. Inspired by the most successful neural source separation systems, it provides all neu-ral building blocks required to build such a system. To improve reproducibility, Kaldi-style recipes on common audio source separation datasets are also provided. This paper describes the software architecture of Asteroid and its most important features. By showing experimental results obtained with Asteroid's recipes, we show that our implementations are at least on par with most results reported in reference papers. The toolkit is publicly available at github.com/mpariente/asteroid.
old_main.pdf (942.46 Ko) Télécharger le fichier
hal-02962964 , version 1 (09-10-2020)
  • HAL Id : hal-02962964 , version 1
Manuel Pariente, Samuele Cornell, Joris Cosentino, Sunit Sivasankaran, Efthymios Tzinis, et al.. Asteroid: the PyTorch-based audio source separation toolkit for researchers. Interspeech 2020, Oct 2020, Shanghai, China. ⟨hal-02962964⟩
480 Consultations
816 Téléchargements
