A Fredholm transformation for the rapid stabilization of a degenerate parabolic equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2021
This paper deals with the rapid stabilization of a degenerate parabolic equation with a right Dirich-let control. Our strategy consists in applying a backstepping strategy, which seeks to find an invertible transformation mapping the degenerate parabolic equation to stabilize into an exponentially stable system whose decay rate is known and as large as we desire. The transformation under consideration in this paper is Fredholm. It involves a kernel solving itself another PDE, at least formally. The main goal of the paper is to prove that the Fredholm transformation is well-defined, continuous and invertible in the natural energy space. It allows us to deduce the rapid stabilization.
submitted.pdf (375.29 Ko) Télécharger le fichier
hal-02963160 , version 1 (09-10-2020)
Ludovick Gagnon, Pierre Lissy, Swann Marx. A Fredholm transformation for the rapid stabilization of a degenerate parabolic equation. SIAM Journal on Control and Optimization, 2021, 59 (5), ⟨10.1137/20M1372603⟩. ⟨hal-02963160⟩
148 Consultations
106 Téléchargements
