Extreme-Density Crowd Simulation: Combining Agents with Smoothed Particle Hydrodynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In highly dense crowds of humans, collisions between people occur often. It is common to simulate such a crowd as one fluid-like entity (macroscopic), and not as a set of individuals (microscopic, agent-based). Agent-based simulations are preferred for lower densities because they preserve the properties of individual people. However, their collision handling is too simplistic for extreme-density crowds. Therefore, neither paradigm is ideal for all possible densities. In this paper, we combine agent-based crowd simulation with the concept of Smoothed Particle Hydrodynamics (SPH), a particle-based method that is popular for fluid simulation. Our combination augments the usual agent-collision handling with fluid dynamics when the crowd density is sufficiently high. A novel component of our method is a dynamic rest density per agent, which intuitively controls the crowd density that an agent is willing to accept. Experiments show that SPH improves agent-based simulation in several ways: better stability at high densities, more intuitive control over the crowd density, and easier replication of wave-propagation effects. Our implementation can simulate tens of thousands of agents in real-time. As such, this work successfully prepares the agent-based paradigm for crowd simulation at all densities.
MIG2020-DenseCrowdsSPH - van Toll et al - Author version.pdf (2.25 Mo) Télécharger le fichier
hal-02964064 , version 1 (12-10-2020)
Wouter van Toll, Cédric Braga, Barbara Solenthaler, Julien Pettré. Extreme-Density Crowd Simulation: Combining Agents with Smoothed Particle Hydrodynamics. MIG 2020 - 13th ACM SIGGRAPH Conference on Motion, Interaction and Games, Oct 2020, Virtual Event, United States. pp.1-10, ⟨10.1145/3424636.3426896⟩. ⟨hal-02964064⟩
276 Consultations
418 Téléchargements
