End-to-end Interpretable Learning of Non-blind Image Deblurring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Non-blind image deblurring is typically formulated as a linear least-squares problem regularized by natural priors on the corresponding sharp picture's gradients, which can be solved, for example, using a half-quadratic splitting method with Richardson fixed-point iterations for its least-squares updates and a proximal operator for the auxiliary variable updates. We propose to precondition the Richardson solver using approximate inverse filters of the (known) blur and natural image prior kernels. Using convolutions instead of a generic linear preconditioner allows extremely efficient parameter sharing across the image, and leads to significant gains in accuracy and/or speed compared to classical FFT and conjugate-gradient methods. More importantly, the proposed architecture is easily adapted to learning both the preconditioner and the proximal operator using CNN embeddings. This yields a simple and efficient algorithm for non-blind image deblurring which is fully interpretable, can be learned end to end, and whose accuracy matches or exceeds the state of the art, quite significantly, in the non-uniform case.
2007.01769.pdf (1.77 Mo) Télécharger le fichier
hal-02966204 , version 1 (13-10-2020)
Thomas Eboli, Jian Sun, Jean Ponce. End-to-end Interpretable Learning of Non-blind Image Deblurring. ECCV 2020 - 16th European Conference on Computer Vision, Aug 2020, Glasgow / Virtual, United Kingdom. ⟨hal-02966204⟩
77 Consultations
99 Téléchargements
