Conference papers
Terminating Non-Disjoint Combined Unification
Abstract : The equational unification problem, where the underlying equational theory may be given as the union of component equational theories, appears often in practice in many fields such as automated reasoning, logic programming, declarative programming, and the formal analysis of security protocols. In this paper, we investigate the unification problem in the non-disjoint union of equational theories via the combination of hierarchical unification procedures. In this context, a unification algorithm known for a base theory is extended with some additional inference rules to take into account the rest of the theory. We show theories for which a hierarchical approach is applicable and present a simple form of hierarchical unification procedure. The approach is particularly well-suited for any theory where a unification procedure can be obtained in a syntactic way using transformation rules to process the axioms of the theory. Hierarchical unification procedures are exemplified with various theories used in protocol analysis. Next, we look at modularity methods for combining theories already using a hierarchical approach. In addition , we consider a new complexity measure that allows us to obtain terminating (combined) hierarchical unification procedures.
Document type :
Conference papers
Complete list of metadatas
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/hal-02967029
Contributor : Christophe Ringeissen <>
Submitted on : Wednesday, October 14, 2020 - 4:08:38 PM
Last modification on : Thursday, October 15, 2020 - 4:10:18 AM
File
combi-hu.pdf
Identifiers
  • HAL Id : hal-02967029, version 1
Collections
Citation
Serdar Erbatur, Andrew Marshall, Christophe Ringeissen. Terminating Non-Disjoint Combined Unification. LOPSTR 2020 - 30th International Symposium on Logic-based Program Synthesis and Transformation, Maurizio Gabbrielli, Sep 2020, Bologna, Italy. ⟨hal-02967029⟩
Share
Metrics
Record views
15
Files downloads
20
