New interface
Journal articles
Competitive effects in bacterial mRNA decay
Thibault Etienne 1, 2 Muriel Cocaign-Bousquet 1 Delphine Ropers 2
2 IBIS - Modeling, simulation, measurement, and control of bacterial regulatory networks
LAPM - Laboratoire Adaptation et pathogénie des micro-organismes [Grenoble], Inria Grenoble - Rhône-Alpes, Institut Jean Roget
Abstract : In living organisms, the same enzyme catalyses the degradation of thousands of different mRNAs, but the possible influence of competing substrates has been largely ignored so far. We develop a simple mechanistic model of the coupled degradation of all cell mRNAs using the total quasi-steady-state approximation of the Michaelis–Menten framework. Numerical simulations of the model using carefully chosen parameters and analyses of rate sensitivity coefficients show how substrate competition alters mRNA decay. The model predictions reproduce and explain a number of experimental observations on mRNA decay following transcription arrest, such as delays before the onset of degradation, the occurrence of variable degradation profiles with increased non linearities and the negative correlation between mRNA half-life and concentration. The competition acts at different levels, through the initial concentration of cell mRNAs and by modifying the enzyme affinity for its targets. The consequence is a global slow down of mRNA decay due to enzyme titration and the amplification of its apparent affinity. Competition happens to stabilize weakly affine mRNAs and to destabilize the most affine ones. We believe that this mechanistic model is an interesting alternative to the exponential models commonly used for the determination of mRNA half-lives. It allows analysing regulatory mechanisms of mRNA degradation and its predictions are directly comparable to experimental data.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-02967513
Contributor : Accord Elsevier CCSD Connect in order to contact the contributor
Submitted on : Monday, August 22, 2022 - 2:49:48 PM
Last modification on : Tuesday, November 8, 2022 - 4:09:44 AM
Long-term archiving on: : Wednesday, November 23, 2022 - 11:00:08 PM
File
S0022519320301880.pdf
Distributed under a Creative Commons Attribution - NonCommercial 4.0 International License
Identifiers
Citation
Thibault Etienne, Muriel Cocaign-Bousquet, Delphine Ropers. Competitive effects in bacterial mRNA decay. Journal of Theoretical Biology, 2020, 504, ⟨10.1016/j.jtbi.2020.110333⟩. ⟨hal-02967513⟩
Share
Metrics
Record views
42
Files downloads
4
