Modelling and Control Structure of a Phosphorite Sinter Process with Grey System Theory
The sintering process of phosphorite ore occurs with a large amount of return caused by untimely process control. The control task of the phosphorite ore sintering is to regulate parameters of the process to obtain a high-quality sinter. The parameter clearly responsible for the sinter quality is the temperature in the wind box (also called burn through point (BTP)). Therefore, in order to solve the real-time control task, it is necessary to predict the BTP. In this paper, the grey system theory is used as a predictive approach, which makes it possible to obtain an adequate model that has the character of a "generalized energy system" and uses a small initial sample. Based on the grey model GMC(1,n), which is constructed in real-time by using real data at the beginning of the process, the temperature is well predicted at the end of the sintering process. When the temperature does not match the set value or to find out an optimal regulation, a control synthesis is carried out through an optimization of the prediction according to the "particle swarm" algorithm.
