Efficient Signatures on Randomizable Ciphertexts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Signatures courtes sur chiffrés randomizables
Randomizable encryption lets anyone randomize a ciphertext so it is distributed like a fresh encryption of the same plaintext. Signatures on randomizable cipher-texts (SoRC), introduced by Blazy et al. (PKC'11), let one adapt a signature on a ciphertext to a randomization of the latter. Since signatures can only be adapted to ciphertexts that encrypt the same message as the signed ciphertext, signatures obliviously authenticate plaintexts. SoRC have been used as a building block in e-voting, blind signatures and (delegatable) anonymous credentials. We observe that SoRC can be seen as signatures on equivalence classes (JoC'19), another primitive with many applications to anonymous authentication, and that SoRC provide better anonymity guarantees. We first strengthen the unforgeability notion for SoRC and then give a scheme that provably achieves it in the generic group model. Signatures in our scheme consist of 4 bilinear-group elements, which is considerably more efficient than prior schemes.
main.pdf (385.64 Ko) Télécharger le fichier
hal-02968280 , version 1 (15-10-2020)
Balthazar Bauer, Georg Fuchsbauer. Efficient Signatures on Randomizable Ciphertexts. SCN 2020 - 12th International Conference Security and Cryptography for Networks., Sep 2020, Amalfi / Virtual, Italy. pp.359-381, ⟨10.1007/978-3-030-57990-6_18⟩. ⟨hal-02968280⟩
507 Consultations
193 Téléchargements
