Navaux. I/o performance of the santos dumont supercomputer, The International Journal of High Performance Computing Applications, vol.34, issue.2, pp.227-245, 2020. ,
Grid'5000: a large scale and highly reconfigurable grid experimental testbed, The 6th IEEE/ACM International Workshop on Grid Computing, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00684943
Understanding and Improving Computational Science Storage Access through Continuous Characterization, ACM Transactions on Storage, vol.7, issue.3, pp.1-26, 2011. ,
Automatic, Application-Aware I/O Forwarding Resource Allocation, 17th USENIX Conference on File and Storage Technologies (FAST 19), pp.265-279, 2019. ,
UMAMI: A recipe for generating meaningful metrics through holistic I/O performance analysis, Proceedings of the 2nd Joint International Workshop on Parallel Data Storage Data Intensive Scalable Computing Systems -PDSW-DISCS '17, pp.55-60, 2017. ,
Optimization techniques at the I/O forwarding layer, Proceedings -IEEE International Conference on Cluster Computing, ICCC, pp.312-321, 2010. ,
Best Practices and Lessons Learned from Deploying and Operating Large-Scale Data-Centric Parallel File Systems, International Conference for High Performance Computing, Networking, Storage and Analysis on (SC), 2014. ,
Accelerating I / O Forwarding in IBM Blue Gene / P Systems, International Conference for High Performance Computing, Networking, Storage and Analysis on (SC), number November, 2010. ,
Applying Machine Learning to Understand Write Performance of Largescale Parallel Filesystems, IEEE/ACM Fourth International Parallel Data Systems Workshop, pp.30-39, 2019. ,
, Hybrid hierarchy storage system in MilkyWay-2 supercomputer, vol.8, pp.367-377, 2014.
End-to-end I / O Monitoring on a Leading Supercomputer, 16th USENIX Symposium on Networked Systems Design and Implementation, NSDI 2019, pp.379-394, 2019. ,
On the load imbalance problem of I/O forwarding layer in HPC systems, 3rd IEEE International Conference on Computer and Communications (ICCC), volume 2018-Janua, pp.2424-2428, 2017. ,
