A combined optimization-simulation approach to the master surgical scheduling problem, IMA Journal of Management Mathematics, vol.24, pp.155-187, 2013. ,
Scheduling admissions and reducing variability in bed demand, Health Care Management Science, vol.14, pp.237-249, 2011. ,
Building cyclic master surgery schedules with leveled resulting bed occupancy, European Journal of Operational Research, vol.176, pp.1185-1204, 2007. ,
Detection Statistics Of Multiple-Pulse Optical Signals Through Atmospheric Turbulence, 2010. ,
Operating room planning and scheduling: A literature review, European Journal of Operational Research, vol.201, pp.921-932, 2010. ,
Bed balancing in surgical wards via block scheduling, Journal of Minimally Invasive Surgical Sciences, vol.2, pp.129-137, 2013. ,
Optimization of surgery sequencing and scheduling decisions under uncertainty, Health Care Management Science, vol.10, pp.13-24, 2007. ,
Optimal allocation of surgery blocks to operating rooms under uncertainty, Operations Research, vol.58, pp.802-816, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00386469
A Methodology for Scheduling Operating Rooms Under Uncertainty, 2013. ,
Modeling length of stay in hospital and other right skewed data: Comparison of phase-type, gamma and log-normal distributions, Value in Health, vol.12, pp.309-314, 2009. ,
The sum of lognormal probability distributions in scatter transmission systems, IRE Transactions on Communications Systems, vol.8, pp.57-67, 1960. ,
Master surgery scheduling with consideration of multiple downstream units, European Journal of Operational Research, vol.239, pp.227-236, 2014. ,
Application of operational research techniques in operating room scheduling problems: Literature overview, Journal of Healthcare Engineering, 2018. ,
Robust surgery loading, European Journal of Operational Research, vol.185, pp.1038-1050, 2008. ,
Adapting ga to solve a novel model for operating room scheduling problem with endogenous uncertainty, Operations Research for Health Care, vol.19, pp.26-43, 2018. ,
A chance-constrained operating room planning with elective and emergency cases under downstream capacity constraints, Computers and Industrial Engineering, vol.114, pp.329-344, 2017. ,
A robust estimation model for surgery durations with temporal, operational, and surgery team effects, Health Care Management Science, vol.18, pp.222-233, 2015. ,
Planning and scheduling operating rooms for elective and emergency surgeries with uncertain duration, Operations Research for Health Care, vol.19, pp.107-119, 2018. ,
Fitting the distributions of length of stay by parametric models, Medical Care, vol.36, pp.915-927, 1998. ,
Approximating a sum of random variables with a lognormal, IEEE Transactions on Wireless Communications, vol.6, pp.2690-2699, 2007. ,
Scheduling elective surgery under uncertainty and downstream capacity constraints, European Journal of Operational Research, vol.206, pp.642-652, 2010. ,
A stochastic approach for solving the operating room scheduling problem, Flexible Services and Manufacturing Journal, vol.30, pp.224-251, 2018. ,
Two-stage robust optimization approach to elective surgery and downstream capacity planning, European Journal of Operational Research, vol.260, pp.21-40, 2017. ,
A stochastic optimization and simulation approach for scheduling operating rooms and recovery beds in an orthopedic surgery department, Computers and Industrial Engineering, vol.80, pp.72-79, 2015. ,
Scheduling surgery groups considering multiple downstream resources, European Journal of Operational Research, vol.282, pp.741-752, 2020. ,
Estimating procedure times for surgeries by determining location parameters for the lognormal model, Health Care Management Science, vol.7, pp.97-104, 2004. ,
Modeling procedure and surgical times for current procedural terminology-anesthesia-surgeon combinations and evaluation in terms of case-duration prediction and operating room efficiency: a multicenter study, Anesthesia and Analgesia, vol.109, pp.1232-1245, 2009. ,
Modeling the uncertainty of surgical procedure times: comparison of log-normal and normal models, Anesthesiology, vol.92, pp.1160-1167, 2000. ,
Reducing the number of required beds by rearranging the or-schedule, OR Spectrum, vol.36, pp.585-605, 2014. ,
A master surgical scheduling approach for cyclic scheduling in operating room departments. OR spectrum, vol.30, pp.355-374, 2008. ,
An exact approach for relating recovering surgical patient workload to the master surgical schedule, Journal of the Operational Research Society, vol.62, pp.1851-1860, 2011. ,
A multi-objective aco for operating room scheduling optimization, Natural Computing, vol.16, pp.607-617, 2017. ,
A mixed integer programming approach for allocating operating room capacity, Journal of Operational Research Society, vol.60, pp.663-673, 2009. ,
Operating room planning and surgical case scheduling: a review of literature, Journal of Combinatorial Optimization, vol.37, pp.757-805, 2019. ,
