The Dynamic Latent Block Model for Sparse and Evolving Count Matrices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider here the problem of co-clustering count matrices with a high level of missing values that may evolve along the time. We introduce a generative model, named dynamic latent block model (dLBM), to handle this situation and which extends the classical binary latent block model (LBM) to the dynamic case. The modeling of the dynamic time framework in a continuous time relies on a non-homogeneous Poisson process, with a latent partition of time intervals. The continuous time is handled by a time partition over the whole considered time period, where the interactions are aggregated on the time intervals of such partition obtaining a sequence of static matrices that allows us to identify meaningful time clusters. We proposed to use the SEM-Gibbs algorithm for model inference and the ICL criterion for model selection. Finally, an application with real-world data is proposed.
the_dynamic_latent_block_model_for_sparse_and_evolving_count_matrices.pdf (599.49 Ko) Télécharger le fichier
hal-02971127 , version 1 (19-10-2020)
  • HAL Id : hal-02971127 , version 1
Giulia Marchello, Marco Corneli, Charles Bouveyron. The Dynamic Latent Block Model for Sparse and Evolving Count Matrices. ICML Workskshop Artemiss, Jul 2020, Nice / Virtual, France. ⟨hal-02971127⟩
83 Consultations
121 Téléchargements
