Rec2Poly: Converting Recursions to Polyhedral Optimized Loops Using an Inspector-Executor Strategy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2020
In this paper, we propose Rec2Poly, a framework which detects automatically if recursive programs may be transformed into affine loops that are compliant with the polyhedral model. If successful, the replacing loops can then take advantage of advanced loop optimizing and parallelizing transformations as tiling or skewing. Rec2Poly is made of two main phases: an offline profiling phase and an inspector-executor phase. In the profiling phase, the original recursive program, which has been instrumented, is run. Whenever possible, the trace of collected information is used to build equivalent affine loops from the runtime behavior. Then, an inspector-executor program is automatically generated, where the inspector is made of a light version of the original recursive program, whose aim is reduced to the generation and verification of the information which is essential to ensure the correctness of the equivalent affine loop program. The collected information is mainly related to the touched memory addresses and the control flow of the so-called "impacting" basic blocks of instructions. Moreover, in order to exhibit the lowest possible time-overhead, the inspector is implemented as a parallel process where several memory buffers of information are verified simultaneously. Finally, the executor is made of the equivalent affine loops that have been optimized and parallelized.
main.pdf (373.58 Ko) Télécharger le fichier
hal-02971434 , version 1 (19-10-2020)
Salwa Kobeissi, Alain Ketterlin, Philippe Clauss. Rec2Poly: Converting Recursions to Polyhedral Optimized Loops Using an Inspector-Executor Strategy. SAMOS 2020: Embedded Computer Systems: Architectures, Modeling, and Simulation, pp.96-109, 2020, ⟨10.1007/978-3-030-60939-9_7⟩. ⟨hal-02971434⟩
100 Consultations
157 Téléchargements
