Individual Brain Charting dataset extension, second release of high-resolution fMRI data for cognitive mapping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Scientific Data Année : 2020
We present an extension of the Individual Brain Charting dataset a high spatial-resolution, multi-task, functional Magnetic Resonance Imaging dataset, intended to support the investigation on the functional principles governing cognition in the human brain. The concomitant data acquisition from the same 12 participants, in the same environment, allows to obtain in the long run finer cognitive topographies, free from inter-subject and inter-site variability. This second release provides more data from psychological domains present in the first release, and also yields data featuring new ones. It includes tasks on e.g. mental time travel,reward, theory-of-mind, pain, numerosity, self-reference effect and speech recognition. In total, 13 tasks with 86 contrasts were added to the dataset and 63 new components were included in the cognitive description of the ensuing contrasts. As the dataset becomes larger, the collection of the corresponding topographies becomes more comprehensive, leading to better brain-atlasing frameworks. This dataset is an open-access facility; raw data and derivatives are publicly available in neuroimaging repositories.
data_paper2_hal.pdf (2.39 Mo) Télécharger le fichier
hal-02973046 , version 1 (20-10-2020)
Ana Luísa Pinho, Alexis Amadon, Baptiste Gauthier, Nicolas Clairis, André Knops, et al.. Individual Brain Charting dataset extension, second release of high-resolution fMRI data for cognitive mapping. Scientific Data , 2020, ⟨10.1038/s41597-020-00670-4⟩. ⟨hal-02973046⟩
254 Consultations
123 Téléchargements
