Dual-Free Stochastic Decentralized Optimization with Variance Reduction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the problem of training machine learning models on distributed data in a decentralized way. For finite-sum problems, fast single-machine algorithms for large datasets rely on stochastic updates combined with variance reduction. Yet, existing decentralized stochastic algorithms either do not obtain the full speedup allowed by stochastic updates, or require oracles that are more expensive than regular gradients. In this work, we introduce a Decentralized stochastic algorithm with Variance Reduction called DVR. DVR only requires computing stochastic gradients of the local functions, and is computationally as fast as a standard stochastic variance-reduced algorithms run on a 1/n fraction of the dataset, where n is the number of nodes. To derive DVR, we use Bregman coordinate descent on a well-chosen dual problem, and obtain a dual-free algorithm using a specific Bregman divergence. We give an accelerated version of DVR based on the Catalyst framework, and illustrate its effectiveness with simulations on real data.
DVR_camera_ready_supp.pdf (898.38 Ko) Télécharger le fichier
hal-02974237 , version 1 (21-10-2020)
  • HAL Id : hal-02974237 , version 1
Hadrien Hendrikx, Francis Bach, Laurent Massoulié. Dual-Free Stochastic Decentralized Optimization with Variance Reduction. NeurIPS 2020 - 34th Conference on Neural Information Processing Systems, Dec 2020, Vancouver / Virtual, Canada. ⟨hal-02974237⟩
3920 Consultations
63 Téléchargements
