Surface heat-flux fluctuations in a turbulent channel flow up to Re? = 1020 with P r = 0.025 and 0.71, Int. J. Heat Fluid Fl, vol.25, issue.3, pp.404-419, 2004. ,
A new turbulence model for predicting fluid flow and heat transfer in separating and reattaching flows-II. Thermal field calculations, Int. J. Heat Mass Tran, vol.38, pp.1467-1481, 1995. ,
Lateral edge effects on heat/mass transfer on a finite width surface within a turbulent boundary layer, Int. J. Heat Mass Tran, vol.138, pp.32-40, 2019. ,
Code Saturne: A Finite Volume Code for the Computation of Turbulent Incompressible flows -Industrial Applications, Int. J. on Finite, issue.0655, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-01115371
Numerical simulations of flow and heat transfer in a wall bounded pin matrix, Flow Turbul. Combust, vol.104, issue.1, pp.19-44, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02179021
A robust k ? ? ? v 2 /k elliptic blending turbulence model applied to near-wall, separated and buoyant flows, Int. J. Heat Fluid Fl, vol.33, issue.1, pp.45-58, 2012. ,
Performance of second-moment differential stress and flux models for natural convection in an enclosure, Int. Commun. Heat Mass Transfer, vol.99, pp.54-61, 2018. ,
Treatment of turbulent heat fluxes with the elliptic-blending second-moment closure for turbulent natural convection flows, Int. J. Heat Mass Tran, vol.51, issue.9, pp.2377-2388, 2008. ,
Towards the development of RANS models for conjugate heat transfer, J. Turbul, vol.11, p.26, 2010. ,
Recent developments in second-moment closure for buoyancy-affected flows, Dyn. Atmos. Oceans, vol.23, issue.1, pp.99-114, 1996. ,
Transport equations in turbulence, Physics of Fluids, vol.13, pp.2634-2649, 1970. ,
Modélisation statistique desécoulements turbulents en convection forcée, mixte et naturelle, 2012. ,
An elliptic blending differential flux model for natural, mixed and forced convection, Int. J. Heat Fluid Fl, vol.63, pp.190-204, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01246134
Numerical prediction of flow and heat transfer in an infinite wire-wrapped fuel assembly, Nucl. Eng. Des, vol.349, pp.193-205, 2019. ,
Near-wall turbulence closure modeling without "damping functions, Theor. Comp. Fluid Dyn, vol.3, issue.1, pp.1-13, 1991. ,
Turbulent time scales and the dissipation rate of temperature variance in the thermal mixing layer, Phys. Fluids, vol.26, pp.2415-2419, 1983. ,
DNS of turbulent channel flow with conjugate heat transfer: Effect of thermal boundary conditions on the second moments and budgets, Int. J. Heat Fluid Fl, vol.55, pp.34-44, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01321586
On the discontinuity of the dissipation rate associated with the temperature variance at the fluid-solid interface for cases with conjugate heat transfer, Int. J. Heat Mass Tran, vol.111, pp.321-328, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01456930
One-point closure models for buoyancy-driven turbulent flows, Annu. Rev. Fluid Mech, vol.34, pp.321-347, 2002. ,
Modelling Turbulence in Engineering and the Environment. Second-Moment Routes to Closure, 2011. ,
Large-eddy simulation in a mixing tee junction: High-order turbulent statistics analysis, Int. J. Heat Fluid Fl, vol.51, pp.65-77, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01138803
Large eddy simulation in code saturne of thermal mixing in a T-junction with brass walls, Int. J. Heat Fluid Fl, vol.63, pp.119-127, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01592931
Closure of the Reynolds stress and scalar flux equations, Phys. Fluids, vol.31, pp.3589-3604, 1988. ,
Direct numerical simulation of passive scalar field in a turbulent channel flow, J. Heat Transf, vol.114, pp.598-606, 1992. ,
Numerical investigation of near-wall turbulent heat transfer taking into account the unsteady heat conduction in the solid wall, J. Heat Transf, vol.111, pp.385-392, 1989. ,
On the computation of convective heat transfer in complex turbulent flows, J. Heat Transf, vol.110, pp.1112-1128, 1988. ,
Recent progress in the development of the elliptic blending Reynolds-stress model, Int. J. Heat Fluid Fl, vol.51, pp.195-220, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01092931
Elliptic blending model: A new near-wall Reynolds-stress turbulence closure, Phys. Fluids, vol.14, issue.2, pp.744-754, 2002. ,
Turbulent heat transfer predictions using the v 2 ? f model on unstructured meshes, Int. J. Heat Fluid Fl, vol.21, issue.3, pp.320-328, 2000. ,
Closure strategies for turbulent and transitional flows, chap. Modelling heat transfer in near-wall flows, pp.188-247, 2002. ,
Modelling the behaviour of homogeneous scalar turbulence, J. Fluid Mech, vol.111, pp.217-232, 1981. ,
Predictions of turbulent heat transfer in an axisymmetric jet impinging on a heated pedestal, J. Heat Transf, vol.120, pp.1-7, 1998. ,
Consistent modeling of scalars in turbulent flows, Phys. Fluids, vol.26, issue.2, pp.404-408, 1983. ,
Second-moment closure for turbulent scalar transport at various Prandtl numbers, Int. J. Heat Mass Tran, vol.39, issue.14, pp.2977-2987, 1996. ,
Elliptic relaxation second moment closure for the turbulent heat fluxes, J. Turbul, vol.9, pp.1-29, 2008. ,
Heat transfer modeling and the assumption of zero wall temperature fluctuations, J. Heat Transf, vol.116, issue.4, pp.855-863, 1994. ,
Concentration fluctuations in a round turbulent free jet, Chem. Eng. Sci, vol.26, issue.1, pp.95-107, 1971. ,
DNS of turbulent heat transfer in channel flow with heat conduction in the solid wall, J. Heat Transf, vol.123, pp.849-857, 2001. ,
RANS modelling for temperature variance in conjugate heat transfer, Proc. 5th World congress on Mechanical, Chemical, and Material Engineering, 2019. ,
Modeling buoyancy driven mixed layers, J. Atmos. Sci, vol.33, pp.1974-1988, 1976. ,
