A learning design recommendation system based on markov decision processes, 17th ACM KDD, 2011. ,
Graph theory based model for learning path recommendation, Information Sciences, vol.251, pp.10-21, 2013. ,
Learning path reco. based on modified variable length genetic algorithm, Education & Inf. Techno, vol.23, issue.2, pp.819-836, 2018. ,
, Item response theory, 2013.
Personalized ranking metric embedding for next new poi recommendation, p.24, 2015. ,
A mining-based approach on discovering courses pattern for constructing suitable learning path, Exp. Syst. with App, vol.37, issue.6, pp.4156-4167, 2010. ,
Patterns and loops: Early computational thinking, Eur. Conf. on Technology Enhanced Learning, pp.280-293, 2019. ,
Exploiting cognitive structure for adaptive learning, Proc. 25th KDD, pp.627-635, 2019. ,
Sequeval: An offline evaluation framework for sequence-based rs, Information, vol.10, issue.5, p.174, 2019. ,
Adaptive lp recommender approach using auxiliary learning objects, Comp. & Educ, vol.147, 2020. ,
Estimating time and score uncertainty in generating successful learning paths under time constraints, Exp. Syst, vol.36, issue.2, 2019. ,
Long term goal oriented recommender systems, Proc. of the 11th Webist, pp.552-557, 2015. ,
Sequence-aware recommender systems, ACM Computing Surveys (CSUR), vol.51, issue.4, pp.1-36, 2018. ,
Contrasting offline and online results when evaluating recommendation algorithms, Proc. 10th RecSys, pp.31-34, 2016. ,
Designing and developing a novel hybrid adaptive learning path recommendation system (alprs) for gamification mathematics geometry course, Science and Technology Education, vol.13, issue.6, pp.2275-2298, 2017. ,
Learning portfolio analysis and mining for scorm compliant environment, J. of Educational Technology & Society, vol.9, issue.1, pp.262-275, 2006. ,
Markov chain and classification of difficulty levels enhances the learning path in one digit multiplication, Int. Conf. on Learning and Collaboration Technologies, pp.322-333, 2014. ,
Using sequential pattern mining to explore learners behaviors and evaluate their correlation with performance in inquiry-based learning, pp.286-299, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01913995
Applying recommender systems and adaptive hypermedia for e-learning personalizatio, Computing and informatics, vol.32, issue.3, pp.629-659, 2013. ,
Discover learning path for group users: A profile-based approach, Neurocomputing, vol.254, pp.59-70, 2017. ,
Personalized learning full-path recommendation model based on lstm neural networks, Inf. Sci, vol.444, pp.135-152, 2018. ,
A multi-constraint learning path recommendation algorithm based on knowledge map, vol.143, pp.102-114, 2018. ,
