Deep Learning-Based Concurrent Brain Registration and Tumor Segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Computational Neuroscience Année : 2020
Image registration and segmentation are the two most studied problems in medical image analysis. Deep learning algorithms have recently gained a lot of attention due to their success and state-of-the-art results in variety of problems and communities. In this paper, we propose a novel, efficient, and multi-task algorithm that addresses the problems of image registration and brain tumor segmentation jointly. Our method exploits the dependencies between these tasks through a natural coupling of their interdependencies during inference. In particular, the similarity constraints are relaxed within the tumor regions using an efficient and relatively simple formulation. We evaluated the performance of our formulation both quantitatively and qualitatively for registration and segmentation problems on two publicly available datasets (BraTS 2018 and OASIS 3), reporting competitive results with other recent state-of-the-art methods. Moreover, our proposed framework reports significant amelioration (p < 0.005) for the registration performance inside the tumor locations, providing a generic method that does not need any predefined conditions (e.g. absence of abnormalities) about the volumes to be registered.
Frontiers(1).pdf (5.08 Mo) Télécharger le fichier
hal-02974826 , version 1 (22-10-2020)
Théo Estienne, Marvin Lerousseau, Maria Vakalopoulou, Emilie Alvarez Andres, Enzo Battistella, et al.. Deep Learning-Based Concurrent Brain Registration and Tumor Segmentation. Frontiers in Computational Neuroscience, 2020, Multimodal Brain Tumor Segmentation and Beyond, ⟨10.3389/fncom.2020.00017⟩. ⟨hal-02974826⟩
149 Consultations
74 Téléchargements
