Correlation between micro-structural features and color of nanocrystallized powders of hematite - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pigments are quite complex materials whose appearance involves many optical phenomena. Here, we focused on hematite as it is a traditional pigment, whose origin of coloration has been well discussed in the literature. Pure nanocrystallized $\alpha-Fe_2O_3$ hematite powders have been synthesized using different synthesis routes. These powders have been characterized by X-Feray powder diffraction and scanning electronic microscopy. The color of the samples has been studied by visible-FeNIR spectrophotometry. We obtained hematite with both various grain morphologies and noticeably different shades going from orange-Fe red to purple. Colorimetric parameters in CIE L*a*b* color space and diffuse reflectance spectra properties were studied against the structural parameters. For small nanocrystals, hue is increasing with the grain size until a critical diameter of about 80 nm, where the trend is reversed. We believe a combination of multiple physical phenomena occurring at this scale may explain this trend.
full_paper.pdf (2.34 Mo) Télécharger le fichier
hal-02975266 , version 1 (22-10-2020)
  • HAL Id : hal-02975266 , version 1
Morgane Gerardin, Nicolas Holzschuch, Alain Ibanez, Bernard Schmitt, Pauline Martinetto. Correlation between micro-structural features and color of nanocrystallized powders of hematite. AIC 2020 - Association Internationale de la Couleur / Couleur Naturelles - Couleurs Numériques, Nov 2020, Avignon, France. pp.1-7. ⟨hal-02975266⟩
214 Consultations
323 Téléchargements
