SCL with Theory Constraints - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year :
(1) , (1) , (1)
1
We lift the SCL calculus for first-order logic without equality to the SCL(T) calculus for first-order logic without equality modulo a background theory. In a nutshell, the SCL(T) calculus describes a new way to guide hierarchic resolution inferences by a partial model assumption instead of an a priori fixed order as done for instance in hierarchic superposition. The model representation consists of ground background theory literals and ground foreground first-order literals. One major advantage of the model guided approach is that clauses generated by SCL(T) enjoy a non-redundancy property that makes expensive testing for tautologies and forward subsumption completely obsolete. SCL(T) is a semi-decision procedure for pure clause sets that are clause sets without first-order function symbols ranging into the background theory sorts. Moreover, SCL(T) can be turned into a decision procedure if the considered combination of a first-order logic modulo a background theory enjoys an abstract finite model property.
2003.04627.pdf (275.53 Ko) Télécharger le fichier
Dates and versions
hal-02975868 , version 1 (23-10-2020)
Identifiers
Cite
Martin Bromberger, Alberto Fiori, Christoph Weidenbach. SCL with Theory Constraints. 2020. ⟨hal-02975868⟩
49 View
52 Download
Share
