Improving Multifrontal Methods by Means of Block Low-Rank Representations, SIAM Journal on Scientific Computing, vol.37, issue.3, pp.1451-1474, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00776859
Block Low-Rank multifrontal solvers: complexity, performance, and scalability, 2017. ,
URL : https://hal.archives-ouvertes.fr/tel-01708791
On the use of low-rank arithmetic to reduce the complexity of parallel sparse linear solvers based on direct factorization techniques, 2018. ,
URL : https://hal.archives-ouvertes.fr/tel-01953908
A Sparse Matrix Arithmetic Based on H-Matrices. Part I: Introduction to H-Matrices, Computing, vol.62, issue.2, pp.89-108, 1999. ,
Data-sparse Approximation by Adaptive H 2 -Matrices, Computing, vol.69, issue.1, pp.1-35, 2002. ,
A robust parallel preconditioner for indefinite systems using hierarchical matrices and randomized sampling, IEEE IPDPS, pp.897-906, 2017. ,
A fast, memory efficient and robust sparse preconditioner based on a multifrontal approach with applications to finiteelement matrices, International Journal for Numerical Methods in Engineering, vol.107, issue.6, pp.520-540, 2016. ,
A survey of direct methods for sparse linear systems, Acta Numerica, vol.25, pp.383-566, 2016. ,
Nested dissection of a regular finite element mesh, SIAM Journal on Numerical Analysis, vol.10, issue.2, pp.345-363, 1973. ,
METIS: A software package for partitioning unstructured graphs, partitioning meshes, and computing fill-reducing orderings of sparse matrices, 1995. ,
Scotch and libScotch 5.1 User's Guide, vol.127, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00410332
A set of level 3 basic linear algebra subprograms, ACM Trans. Math. Softw, vol.16, issue.1, pp.1-17, 1990. ,
PaStiX: A High-Performance Parallel Direct Solver for Sparse Symmetric Definite Systems, Parallel Computing, vol.28, issue.2, pp.301-321, 2002. ,
An Efficient Solver for Sparse Linear Systems Based on Rank-Structured Cholesky Factorization, CoRR, 2015. ,
Models of computation -exploring the power of computing, 1998. ,
Memory and data aware scheduling, 2018. ,
Multidimensional knapsack problems," in Knapsack problems, pp.235-283, 2004. ,
Introduction to approximation and online algorithms, 2016. ,
Fast methods for estimating the numerical rank of large matrices, ICML, pp.468-477, 2016. ,
Fast and accurate simulation of multithreaded sparse linear algebra solvers, IEEE ICPADS, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01180272
The University of Florida sparse matrix collection, ACM Trans. Math. Softw, vol.38, issue.1, 2011. ,
Controlling the Memory Subscription of Distributed Applications with a Task-Based Runtime System, HIPS, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01284004
, Saint Ismier Cedex Publisher Inria Domaine de Voluceau -Rocquencourt BP 105 -78153 Le Chesnay Cedex inria
