, Kymatio: Scattering transforms in python. CoRR, 2018.
URL : https://hal.archives-ouvertes.fr/hal-02945354
A fast iterative shrinkage-thresholding algorithm for linear inverse problems, SIAM J. Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
Invariant scattering convolution networks, IEEE Trans. Pattern Anal. Mach. Intell, vol.35, issue.8, pp.1872-1886, 2013. ,
Robust uncertainty principles: exact signal reconstruction from highly incomplete frequency information, IEEE Transactions on Information Theory, vol.52, issue.2, pp.489-509, 2006. ,
Proximal splitting methods in signal processing, Fixed-Point Algorithms for Inverse Problems in Science and Engineering, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00643807
An iterative thresholding algorithm for linear inverse problems with a sparsity constraint, Communications on Pure and Applied Mathematics, vol.57, issue.11, pp.1413-1457, 2004. ,
Adaptive greedy approximations, Constr. Approx, vol.13, issue.1, pp.57-98, 1997. ,
On the stability of the basis pursuit in the presence of noise, Signal Processing, vol.86, issue.3, pp.511-532, 2006. ,
Fast solution of l 1 -norm minimization problems when the solution may be sparse, IEEE Trans. Information Theory, vol.54, issue.11, pp.4789-4812, 2008. ,
Learning fast approximations of sparse coding, ICML, pp.399-406, 2010. ,
Iterative soft/hard thresholding with homotopy continuation for sparse recovery, IEEE Signal Processing Letters, vol.24, issue.6, pp.784-788, 2017. ,
Imagenet classification with deep convolutional neural networks, Advances in Neural Information Processing Systems, vol.25, pp.1097-1105, 2012. ,
Deep learning, Nature, vol.521, issue.7553, pp.436-444, 2015. ,
ALISTA: Analytic weights are as good as learned weights in LISTA, International Conference on Learning Representations, 2019. ,
Deep dictionary learning: A parametric network approach, IEEE Transactions on Image Processing, vol.28, issue.10, pp.4790-4802, 2019. ,
Supervised dictionary learning, Advances in neural information processing systems, pp.1033-1040, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00322431
Task-driven dictionary learning, IEEE transactions on pattern analysis and machine intelligence, vol.34, pp.791-804, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00521534
Group invariant scattering, Comm. Pure Appl. Math, vol.65, issue.10, pp.1331-1398, 2012. ,
Understanding deep convolutional networks, Phil. Trans. of Royal Society A, vol.374, 2016. ,
Matching pursuits with time-frequency dictionaries, Trans. Sig. Proc, vol.41, issue.12, pp.3397-3415, 1993. ,
A new approach to variable selection in least squares problems, IMA journal of numerical analysis, vol.20, issue.3, p.389, 2000. ,
Deep roto-translation scattering for object classification, IEEE Conference on Computer Vision and Pattern Recognition (CVPR), pp.2865-2873, 2014. ,
Scaling the scattering transform: Deep hybrid networks, Proceedings of the IEEE international conference on computer vision, pp.5618-5627, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01495734
Scattering networks for hybrid representation learning, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.41, issue.9, pp.2208-2221, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01837587
Convolutional neural networks analyzed via convolutional sparse coding, Journal of Machine Learning Research, vol.18, p.52, 2017. ,
Fisher vectors meet neural networks: A hybrid classification architecture, IEEE Conference on Computer Vision and Pattern Recognition (CVPR), pp.3743-3752, 2015. ,
ImageNet Large Scale Visual Recognition Challenge, International Journal of Computer Vision (IJCV), vol.115, issue.3, pp.211-252, 2015. ,
Multilayer convolutional sparse modeling: Pursuit and dictionary learning, IEEE Transactions on Signal Processing, vol.66, issue.15, pp.4090-4104, 2018. ,
Supervised deep sparse coding networks, 25th IEEE International Conference on Image Processing (ICIP), pp.346-350, 2018. ,
High-dimensional signature compression for large-scale image classification, CVPR, pp.1665-1672, 2011. ,
A proximal-gradient homotopy method for the sparse least-square problem, SIAM Journl on Optimization, vol.23, issue.2, pp.1062-1091, 2013. ,
