Nonlinear feedback design for fixed-time stabilization of linear control systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00757561
Sliding mode control: Theory and applications, 1998. ,
Higher-order sliding modes, differentiation and output feedback control, International Journal of Control, vol.76, issue.9, pp.924-941, 2003. ,
When is it reasonable to implement the discontinuous sliding-mode controllers instead of the continuous ones? Frequency domain criteria, International Journal of Robust and Nonlinear Control, vol.29, issue.3, pp.810-828, 2019. ,
Homogeneity approach to high-order sliding mode design, Automatica, vol.41, issue.5, pp.823-830, 2005. ,
Strict Lyapunov functions for the super-twisting algorithm, IEEE Transactions on Automatic Control, vol.57, issue.4, pp.1035-1040, 2012. ,
Simple homogeneous sliding-mode controller, Automatica, vol.67, pp.22-32, 2016. ,
Homogeneous high order sliding mode design: A Lyapunov approach, Automatica, vol.80, pp.232-238, 2017. ,
A solution of the problem of synthesis using a controllability function, Doklady Academii Nauk SSSR, vol.248, issue.5, pp.1051-1055, 1979. ,
, Soft variable-structure controls: a survey, vol.40, pp.1821-1844, 2004.
, Finite-time stabilization using implicit Lyapunov function technique, pp.140-145, 2013.
URL : https://hal.archives-ouvertes.fr/hal-00844386
Sliding mode control design for MIMO systems, Implicit Lyapunov function approach, pp.2612-2617, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01003984
, Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, vol.51, pp.332-340, 2015.
URL : https://hal.archives-ouvertes.fr/hal-01098099
Robust stabilization of MIMO systems in finite/fixed time, International Journal of Robust and Nonlinear Control, vol.26, issue.1, pp.69-90, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01160052
Synthesis of gain-scheduled controller for a class of LPV systems, Proceedings of the 38th IEEE Conference on Decision and Control, pp.2314-2319, 1999. ,
LPV controller design for the nonlinear RTAC system, International Journal of Robust and Nonlinear Control, vol.11, issue.14, pp.1343-1363, 2001. ,
Model construction, rule reduction, and robust compensation for generalized form of Takagi-Sugeno fuzzy systems, IEEE Transactions on Fuzzy Systems, vol.9, issue.4, pp.525-538, 2001. ,
, Fuzzy Control Systems Design and Analysis: A Linear Matrix Inequality Approach, 2001.
Polynomial fuzzy models for nonlinear control: a Taylor series approach, IEEE Transactions on Fuzzy Systems, vol.17, issue.6, pp.1284-1295, 2009. ,
, Linear matrix inequalities in system and control theory, vol.15, 1994.
, LMI control toolbox, Math Works, 1995.
Using SeDuMi 1.02, a MATLAB toolbox for optimization over symmetric cones, Optimization Methods and Software, vol.11, issue.1-4, pp.625-653, 1999. ,
A practical method for the design of sliding mode controllers using linear matrix inequalities, Automatica, vol.40, issue.10, pp.1761-1769, 2004. ,
LMI-based sliding-mode observer design method, Control Theory and Applications, IEE Proceedings, vol.152, issue.1, pp.113-115, 2005. ,
Sliding subspace design based on linear matrix inequalities, Kybernetika, vol.50, issue.3, pp.436-449, 2014. ,
LMI-based second order sliding set design using reduced order of derivatives, International Journal of Robust and Nonlinear Control, vol.25, issue.18, pp.3763-3779, 2015. ,
An LMI approach for second-order sliding set design using piecewise Lyapunov functions, Automatica, vol.79, pp.61-64, 2017. ,
Nonlinear sliding mode control design: an LMI approach, Systems & Control Letters, vol.104, pp.38-44, 2017. ,
Relaxed LMI conditions for closed-loop fuzzy systems with tensor-product structure, Engineering Applications of Artificial Intelligence, vol.20, issue.8, pp.1036-1046, 2007. ,
Finite time stability and robust control synthesis of uncertain switched systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
Differential Equations with Discontinuous Right-hand Sides, 1988. ,
, Introduction to Calculus and Analysis, 1999.
Nonlinear Control Systems, 1995. ,
