Data mining: the textbook, 2015. ,
, Application and significance of web usage mining in the 21st century: a literature review, Int. Journal of Computer Theory and Engineering, vol.8, issue.1, p.41, 2016.
Sequential pattern mining using a bitmap representation, 8th ACM SIGKDD Int. Conf. on Knowledge discovery and data mining, pp.429-435, 2002. ,
Multi-relational data mining: an introduction, ACM SIGKDD Explorations Newsletter, vol.5, issue.1, pp.1-16, 2003. ,
The spmf open-source data mining library version 2, ECML-PKDD, pp.36-40, 2016. ,
A survey of sequential pattern mining, Data Science and Pattern Recognition, vol.1, issue.1, pp.54-77, 2017. ,
, Data mining: concepts and techniques, 2011.
Modéliser la diversité au cours du temps pour comprendre le contexte de l'utilisateur dans les systèmes de recommandation, 2018. ,
Prefixspan: Mining sequential patterns efficiently by prefixprojected pattern growth, 17th ICDE, pp.215-224, 2001. ,
Multidimensional sequential pattern mining, CIKM, pp.81-88, 2001. ,
Analyzing online consumer behavior in mobile and pc devices: A novel web usage mining approach. Electronic commerce research and applications, vol.26, pp.1-12, 2017. ,
Mining text patterns for synonyms extraction, 2011 22nd Int. Workshop on Database and Expert Systems Applications, pp.473-477, 2011. ,
Mining globally interesting patterns from multiple databases using kernel estimation, Expert Systems with Applications, vol.36, issue.8, pp.10863-10869, 2009. ,
Algorithms for context based sequential pattern mining, Fundamenta Informaticae, vol.76, issue.4, pp.495-510, 2007. ,
