Optimizing bacterial resource allocation: metabolite production in continuous bioreactors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We show preliminary results addressing the problem of resource allocation in bacteria in the continuous bioreactor framework. We propose a coarse-grained self-replicator dynamical model that accounts for the microbial population growth inside a continuous bioreactor, and we study its asymptotic behavior through a dynamical systems analysis approach, in order to provide conditions for the persistence of the bacterial population. We then study the two most relevant cases of steady-state production in this scheme: 1) biomass production, classical in high-tech industrial processes as well as in research environments; and 2) metabolite production through the introduction of a heterologous metabolic pathway. Both problems are explored in terms of the internal allocation control-which can be externally disrupted-and the constant volumetric flow of the bioreactor; and analyzed through a numerical approach. The resulting two-dimensional optimization problem is defined in terms of Michaelis-Menten kinetics using the parameter values of previous works, and taking into account the constraints for the existence of the equilibrium of interest.
IFAC.pdf (2.48 Mo) Télécharger le fichier
hal-02980429 , version 1 (26-11-2020)
  • HAL Id : hal-02980429 , version 1
Agustín Gabriel Yabo, Jean-Luc Gouzé. Optimizing bacterial resource allocation: metabolite production in continuous bioreactors. IFAC 2020 - 1st Virtual World Congress by the International Federation of Automatic Control, Jul 2020, Berlin / Virtual, Germany. ⟨hal-02980429⟩
114 Consultations
73 Téléchargements
