Evolving the behavior of machines: from micro to macroevolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue iScience Année : 2020
Evolution gave rise to creatures that are arguably more sophisticated than the greatest human-designed systems. This feat has inspired computer scientists since the advent of computing and led to optimization tools that can evolve complex neural networks for machines-an approach known as "neuroevolution". After a few successes in designing evolvable representations for high-dimensional artifacts, the field has been recently revitalized by going beyond optimization: to many, the wonder of evolution is less in the perfect optimization of each species than in the creativity of such a simple iterative process, that is, in the diversity of species. This modern view of artificial evolution is moving the field away from microevolution, following a fitness gradient in a niche, to macroevolution, filling many niches with highly different species. It already opened promising applications, like evolving gait repertoires, video game levels for different tastes, and diverse designs for aerodynamic bikes.
mouret-light.pdf (948.82 Ko) Télécharger le fichier
hal-02982114 , version 1 (28-10-2020)
hal-02982114 , version 2 (14-12-2020)
Jean-Baptiste Mouret. Evolving the behavior of machines: from micro to macroevolution. iScience, 2020, pp.101731. ⟨10.1016/j.isci.2020.101731⟩. ⟨hal-02982114v1⟩
98 Consultations
191 Téléchargements
