Generative adversarial networks as a novel approach for tectonic fault and fracture extraction in high resolution satellite and airborne optical images
We develop a novel method based on Deep Convolutional Networks (DCN) to automate the identification and mapping of fracture and fault traces in optical images. The method employs two DCNs in a two players game: a first network, called Generator, learns to segment images to make them resembling the ground truth; a second network, called Discriminator, measures the differences between the ground truth image and each segmented image and sends its score feedback to the Generator; based on these scores, the Generator improves its segmentation progressively. As we condition both networks to the ground truth images, the method is called Conditional Generative Adversarial Network (CGAN). We propose a new loss function for both the Generator and the Discriminator networks, to improve their accuracy. Using two criteria and a manually annotated optical image, we compare the generalization performance of the proposed method to that of a classical DCN architecture, U-net. The comparison demonstrates the suitability of the proposed CGAN architecture. Further work is however needed to improve its efficiency.
Domains
Computer Science [cs] Computer Vision and Pattern Recognition [cs.CV] Computer Science [cs] Machine Learning [cs.LG] Computer Science [cs] Neural and Evolutionary Computing [cs.NE] Computer Science [cs] Signal and Image Processing Computer Science [cs] Sciences of the Universe [physics] Earth Sciences
