Emotion recognition from phoneme-duration information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
The duration of each phoneme is extracted for several emotions. Information on phonemes and their duration are used to train a Variational AutoEncoder (VAE) to create a latent space z which represents emotion information. The loss functions that were used for that purpose are reconstruction loss, Kullback-Leibler (KL) divergence and multiclass N pair loss. Test samples are classified using the nearest neighbor criterion between their representation and the clusters associated to each emotion, as estimated from training data. To evaluate the models two metrics were used: emotion recognition accuracy and the consistency of the clusters of the latent space.
ISSP_2020_submitted.pdf (191.67 Ko) Télécharger le fichier
hal-02983229 , version 1 (29-10-2020)
  • HAL Id : hal-02983229 , version 1
Ajinkya Kulkarni, Ioannis K Douros, Vincent Colotte, Denis Jouvet. Emotion recognition from phoneme-duration information. 2020. ⟨hal-02983229⟩
102 Consultations
167 Téléchargements
