Optimal transport between determinantal point processes and application to fast simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Modern Stochastics: Theory and Applications Année : 2021
We analyze several optimal transportation problems between de-terminantal point processes. We show how to estimate some of the distances between distributions of DPP they induce. We then apply these results to evaluate the accuracy of a new and fast DPP simulation algorithm. We can now simulate in a reasonable amount of time more than ten thousands points.
decreusefond_moroz.pdf (526.06 Ko) Télécharger le fichier
hal-02984323 , version 1 (30-10-2020)
Laurent Decreusefond, Guillaume Moroz. Optimal transport between determinantal point processes and application to fast simulation. Modern Stochastics: Theory and Applications, 2021, 8 (2), pp.209--237. ⟨10.15559/21-VMSTA180⟩. ⟨hal-02984323⟩
339 Consultations
251 Téléchargements
