Local (T)HB-spline projectors via restricted hierarchical spline fitting - Archive ouverte HAL Access content directly
Journal Articles Computer Aided Geometric Design Year : 2020
(1) , (2) , (3, 4)
1
2
3
4
This paper is devoted to techniques for adaptive spline projection via quasi-interpolation, enabling the efficient approximation of given functions. We employ local least-squares fitting in restricted hierarchical spline spaces to establish novel projection operators for hierarchical splines of degree p. This leads to efficient spline projectors that require O(p d) floating point operations and O(1) evaluations of the given function per degree of freedom, while providing essentially the same accuracy as global approximation. Our spline projectors are based on a unifying framework for quasi-interpolation in hierarchical spline spaces. We present a detailed comparison with the scheme of Speleers and Manni (2016).
paper.pdf (1.19 Mo) Télécharger le fichier
Format : Figure, Image
Dates and versions
hal-02985011 , version 1 (01-11-2020)
Identifiers
Cite
Alessandro Giust, Bert Jüttler, Angelos Mantzaflaris. Local (T)HB-spline projectors via restricted hierarchical spline fitting. Computer Aided Geometric Design, 2020, 80, pp.101865. ⟨10.1016/j.cagd.2020.101865⟩. ⟨hal-02985011⟩
40 View
106 Download
Share
