, , 1996.
Optimal design for minimum weight and compliance in plane stress using extremal microstructures, European Journal of Mechanics, A/Solids, vol.12, issue.6, pp.839-878, 1993. ,
A computational procedure for part design, Computer Methods in Applied Mechanics and Engineering, vol.97, pp.33-48, 1992. ,
Evolutionary Algorithms in theory and practice, 1995. ,
Evolution strategies for mixed-integer optimization of optical multilayer systems, Proceedings of the 4 th Annual Conference on Evolutionary Programming, 1995. ,
A comparative study of a penalty function, a repair heuristic and stochastic operators with set covering problem, Arti cial Evolution, number 1063 in LNCS, 1995. ,
An overview of evolutionary algorithms for parameter optimization, Evolutionary Computation, vol.1, issue.1, pp.1-23, 1993. ,
Hadj-Alouane. A dual genetic algorithm for bounded integer programs, 1992. ,
Generating optimal topologies in structural design using a homogenization method, Computer Methods in Applied Mechanics and Engineering, vol.71, pp.197-224, 1988. ,
Using a genetic algorithm to design binary phase-only lters for pattern recognition, Proceedings of the 4 th International Conference on Genetic Algorithms, 1991. ,
Problems of shape optimum design, Optimization of distributed parameter structures, vol.II, 1981. ,
Une th eorie assymptotique des algorithmes g en etiques, 1994. ,
An asymptotic theory of genetic algorithms, Arti cial Evolution, vol.1063, 1996. ,
Genetic algorithm-based structural topology design with compliance and topology simpli cation considerations, Journal of Mechanical Design, 1995. ,
Genetic algorithms as an approach to con guration and topology design, Journal of Mechanical Design, vol.116, pp.1005-1012, 1994. ,
Three-Dimensional Elasticity, Mathematical Elasticity, vol.I, 1978. ,
URL : https://hal.archives-ouvertes.fr/hal-01077590
The Finite Element Method for Elliptic Problems, 1988. ,
Are genetic algorithms function optimizers, Proceedings of the 2 nd Conference on Parallel Problems Solving from Nature, pp.3-13, 1992. ,
Evolutionary Computation. Toward a New Philosophy of Machine Intelligence, 1995. ,
Analysis of a part design procedure, 1995. ,
Genetic algorithms in search, optimization and machine learning, 1989. ,
Genetic algorithms with sharing for multi-modal function optimization, Proceedings of the 2 nd International Conference on Genetic Algorithms, pp.41-49, 1987. ,
Engineering optimization via genetic algorithms, Proceedings of the ninth Conference on Electronic Computation, pp.471-482, 1986. ,
Discrete optimal design using a genetic algorithm, Topology Design of Structures, pages 117{133. NATO Series, 1993. ,
Optimization and Arti cial Intelligence in Civil and Structural Engineering, Genetic Algorithms in Automated Structural Synthesis, vol.1, pp.639-653, 1992. ,
Topology Design of Structures, chapter, Structural Topology Optimization. NATO Series, 1993. ,
Adaptation in natural and arti cial systems, 1975. ,
Topological Structural Design using Genetic Algorithms, 1992. ,
On the use of non-stationary penalty functions to solve nonlinear constrained optimization problems with GAs, Proceedings of the First IEEE International Conference on Evolutionary Computation, pp.579-584, 1994. ,
Mod elisation math ematique de l' il en elasticit e non-lin eaire, volume RMA 26, 1993. ,
Algorithmes g en etiques et Optimisation topologique, 1996. ,
Structural topology optimization in linear and nonlinear elasticity using genetic algorithms, Proceedings of the ASME 21st Design Automation Conference, 1995. ,
Genetic operators for two-dimensional shape optimization ,
, Arti cial Evolution, 1995.
Optimization by simulated annealing, Science, vol.220, pp.671-680, 1983. ,
Optimization of laminate stacking sequence for buckling load maximization by genetic algorithms, AIAA Journal, vol.31, issue.5, pp.951-970, 1993. ,
Genetic search strategies in large scale optimization, Structures, Structural Dynamics, and Materials Conference, 1993. ,
A comparison of parallel and sequential niching techniques, Proceedings of the 6 th International Conference on Genetic Algorithms, pp.136-143, 1995. ,
Synthesis of optical multi-layer systems using genetic algorithms, Applied Optics, vol.34, p.2267, 1995. ,
Genetic Algorithms+Data Structures=Evolution Programs, 1996. ,
Handling constraints in genetic algorithms, Proceedings of the 4 th International Conference on Genetic Algorithms, pp.151-157, 1991. ,
Evolutionary Algorithms for Constrained Parameter Optimization Problems, Evolutionary Computation, vol.4, issue.1, 1996. ,
Radcli e. Equivalence class analysis of genetic algorithms, Complex Systems, vol.5, pp.183-203, 1991. ,
Fitness variance of formae and performance prediction, Foundations of Genetic Algorithms, vol.3, pp.51-72, 1994. ,
Multiple objective optimization with vector evaluated genetic algorithms ,
, Proceedings of the 1 st International Conference on Genetic Algorithms. Laurence Erlbaum Associates, 1985.
Representations for evolutionary optimization and identi cation in structural mechanics, Genetic Algorithms in Engineering and Computer Sciences, pp.443-464, 1995. ,
Shape representations and evolution schemes, Proceedings of the 5 th Annual Conference on Evolutionary Programming, 1996. ,
Evolutionary computation at the edge of feasibility, Proceedings of the 4 th Conference on Parallel Problems Solving from Nature, 1996. ,
Discrete optimal design of structures by genetic algorithms, Conf erence Nationale sur le Calcul de Structures. Hermes, 1993. ,
Numerical Optimization of Computer Models, 1981. ,
Genetic optimization using a penalty function, Proceedings of the 5 th International Conference on Genetic Algorithms, pp.499-503, 1993. ,
A multi-objective approach to constrained optimization of gas supply networks, Proceedings of the AISB-95 Workshop on Evolutionary Computing, vol.993, pp.166-180, 1995. ,
Uniform crossover in genetic algorithms, Proceedings of the 3 rd International Conference on Genetic Algorithms, pp.2-9, 1989. ,
Optimisations g en etiques en M ecanique des Solides, 1996. ,
