New interface
Conference papers
Controlling Crossover through Inductive Learning
Abstract : Crossover may achieve the fast combination of performant building blocks ; but as a counterpart, crossover may as well break a newly discovered building block. We propose to use inductive learning to control such disruptive effects of crossover. The idea is to periodically gather some examples of crossovers, labelled as "good" or "bad" crossovers according to their effects on the current population. From these examples, inductive learning builds rules characterizing the crossover quality. This ruleset then enables to control further evolution : crossovers classified "bad" according to the ruleset are refused. Some experimentations on the Royal Road problem are discussed.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-02985520
Contributor : Marc Schoenauer Connect in order to contact the contributor
Submitted on : Monday, November 2, 2020 - 11:45:05 AM
Last modification on : Saturday, October 22, 2022 - 4:55:25 AM
File
sebagSchoenauerPPSN94.pdf
Identifiers
  • HAL Id : hal-02985520, version 1
Citation
Michèle Sebag, Marc Schoenauer. Controlling Crossover through Inductive Learning. Proc. PPSN III - Parallel Problem Solving from Nature, Sep 1994, Jerusalem, Israel. pp.209-218. ⟨hal-02985520⟩
Share
Metrics
Record views
42
Files downloads
59
