DNN-based mask estimation for distributed speech enhancement in spatially unconstrained microphone arrays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE/ACM Transactions on Audio, Speech and Language Processing Année : 2021
Deep neural network (DNN)-based speech enhancement algorithms in microphone arrays have now proven to be efficient solutions to speech understanding and speech recognition in noisy environments. However, in the context of ad-hoc microphone arrays, many challenges remain and raise the need for distributed processing. In this paper, we propose to extend a previously introduced distributed DNN-based time-frequency mask estimation scheme that can efficiently use spatial information in form of so-called compressed signals which are pre-filtered target estimations. We study the performance of this algorithm named Tango under realistic acoustic conditions and investigate practical aspects of its optimal application. We show that the nodes in the microphone array cooperate by taking profit of their spatial coverage in the room. We also propose to use the compressed signals not only to convey the target estimation but also the noise estimation in order to exploit the acoustic diversity recorded throughout the microphone array.
furnon.pdf (3.57 Mo) Télécharger le fichier
mask_on_z_distant.pdf (17.22 Ko) Télécharger le fichier
mask_on_z_local.pdf (17.19 Ko) Télécharger le fichier
sigex.pdf (292.45 Ko) Télécharger le fichier
step2.pdf (31.75 Ko) Télécharger le fichier
tango_nn_v2.pdf (46.83 Ko) Télécharger le fichier
hal-02985867 , version 1 (02-11-2020)
hal-02985867 , version 2 (19-05-2021)
hal-02985867 , version 3 (20-08-2021)
Nicolas Furnon, Romain Serizel, Slim Essid, Irina Illina. DNN-based mask estimation for distributed speech enhancement in spatially unconstrained microphone arrays. IEEE/ACM Transactions on Audio, Speech and Language Processing, 2021, 29, pp.2310 - 2323. ⟨10.1109/TASLP.2021.3092838⟩. ⟨hal-02985867v3⟩
228 Consultations
306 Téléchargements
