Bin Packing Problem with Time Lags - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue INFORMS Journal on Computing Année : 2022
We introduce and motivate a variant of the bin packing problem where bins are assigned to time slots, and minimum and maximum lags are required between some pairs of items. We suggest two integer programming formulations for the problem: a compact one, and a stronger formulation with an exponential number of variables and constraints. We propose a branch-cut-and-price approach which exploits the latter formulation. For this purpose, we devise separation algorithms based on a mathematical characterization of feasible assignments for two important special cases of the problem. Computational experiments are reported for instances inspired from a real-case application of chemical treatment planning in vineyards, as well as for literature instances for special cases of the problem. The experimental results show the efficiency of our branch-cut-and-price approach, as it outperforms the compact formulation of newly proposed instances, and is able to obtain improved lower and upper bounds for literature instances.
main_final_clear.pdf (538.81 Ko) Télécharger le fichier
hal-02986895 , version 1 (03-11-2020)
hal-02986895 , version 2 (14-12-2022)
Orlando Rivera Letelier, François Clautiaux, Ruslan Sadykov. Bin Packing Problem with Time Lags. INFORMS Journal on Computing, 2022, 34 (4), pp.2249-2270. ⟨10.1287/ijoc.2022.1165⟩. ⟨hal-02986895v2⟩
174 Consultations
647 Téléchargements
