A stabilized branch-and-price-and-cut algorithm for the multiple length cutting stock problem, Computers & Operations Research, vol.35, issue.4, pp.1315-1328, 2008. ,
A hybrid improvement heuristic for the one-dimensional bin packing problem, Journal of Heuristics, vol.10, issue.2, pp.205-229, 2004. ,
An exact algorithm for the vehicle routing problem based on the set partitioning formulation with additional cuts, Mathematical Programming, vol.115, issue.2, pp.351-385, 2007. ,
Branchand-price and beam search algorithms for the variable cost and size bin packing problem with optional items, Annals of Operations Research, vol.222, issue.1, pp.125-141, 2014. ,
A branch-and-cut-and-price algorithm for one-dimensional stock cutting and two-dimensional two-stage cutting, European Journal of Operational Research, vol.171, issue.1, pp.85-106, 2006. ,
Bin packing and related problems: General arc-flow formulation with graph compression, Computers & Operations Research, vol.69, pp.56-67, 2016. ,
Lower bounds and algorithms for the 2-dimensional vector packing problem, Discrete Applied Mathematics, vol.111, issue.3, pp.231-262, 2001. ,
A new exact algorithm for the multi-depot vehicle routing problem under capacity and route length constraints, Discrete Optimization, vol.12, pp.129-146, 2014. ,
Exact Branch-Price-and-Cut Algorithms for Vehicle Routing, Transportation Science, vol.53, issue.4, pp.946-985, 2019. ,
Enhanced Pseudo-polynomial Formulations for Bin Packing and Cutting Stock Problems, INFORMS Journal on Computing, vol.32, issue.1, pp.101-119, 2020. ,
Bin packing and cutting stock problems: Mathematical models and exact algorithms, European Journal of Operational Research, vol.255, issue.1, pp.1-20, 2016. ,
JuMP: A Modeling Language for Mathematical Optimization, SIAM Review, vol.59, issue.2, pp.295-320, 2017. ,
A hybrid grouping genetic algorithm for bin packing, Journal of Heuristics, vol.2, issue.1, pp.5-30, 1996. ,
New classes of fast lower bounds for bin packing problems. Mathematical programming, vol.91, pp.11-31, 2001. ,
A new branching strategy for time constrained routing problems with application to backhauling, Annals of Operations Research, vol.61, issue.1, pp.91-109, 1995. ,
A linear programming approach to the cutting-stock problem, Operations research, vol.9, issue.6, pp.849-859, 1961. ,
Relaxations and exact solution of the variable sized bin packing problem, Computational Optimization and Applications, vol.48, issue.2, pp.345-368, 2009. ,
Maximum-weight stable sets and safe lower bounds for graph coloring, Mathematical Programming Computation, vol.4, issue.4, pp.363-381, 2012. ,
Stabilized branch-and-price algorithms for vector packing problems, European Journal of Operational Research, vol.271, issue.2, pp.401-419, 2018. ,
Shortest Path Problems with Resource Constraints, Column Generation, pp.33-65 ,
Subset-Row Inequalities Applied to the Vehicle-Routing Problem with Time Windows, Operations Research, vol.56, issue.2, pp.497-511, 2008. ,
Mathematical methods of organizing and planning production, Management science, vol.6, issue.4, pp.366-422, 1960. ,
Algorithms for packing and scheduling problems, Quarterly Journal of the Belgian, French and Italian Operations Research Societies, vol.1, issue.1, 2003. ,
Improved Branch-Cut-and-Price for Capacitated Vehicle Routing, Integer Programming and Combinatorial Optimization, vol.8494, pp.393-403, 2014. ,
New Enhancements for the Exact Solution of the Vehicle Routing Problem with Time Windows, INFORMS Journal on Computing, vol.29, issue.3, pp.489-502, 2017. ,
Improved branch-cut-and-price for capacitated vehicle routing, Mathematical Programming Computation, vol.9, issue.1, pp.61-100, 2016. ,
Limited memory Rank-1 Cuts for Vehicle Routing Problems, Operations Research Letters, vol.45, issue.3, pp.206-209, 2017. ,
Enhanced Branch-Cut-and-Price algorithm for heterogeneous fleet vehicle routing problems, European Journal of Operational Research, vol.270, issue.2, pp.530-543, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01664844
Automation and Combination of Linear-Programming Based Stabilization Techniques in Column Generation, INFORMS Journal on Computing, vol.30, issue.2, pp.339-360, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01077984
A generic exact solver for vehicle routing and related problems, Mathematical Programming, vol.183, issue.1-2, pp.483-523, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02178171
A Generic Exact Solver for Vehicle Routing and Related Problems, Integer Programming and Combinatorial Optimization, pp.354-369, 2019. ,
Knapsack problems, 2004. ,
A Minimal Algorithm for the 0-1 Knapsack Problem, Operations Research, vol.45, issue.5, pp.758-767, 1997. ,
An integer programming approach to scheduling, Computer Scheduling of Public Transport: Urban Passenger Vehicle and Crew Scheduling, pp.269-280, 1981. ,
A Bucket Graph?Based Labeling Algorithm with Application to Vehicle Routing, Transportation Science, p.2020, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-01664854
Primal Heuristics for Branch and Price: The Assets of Diving Methods, INFORMS Journal on Computing, vol.31, issue.2, pp.251-267, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01237204
us army army missile command sinosoviet bloc missile and space technology june 1965 top secret dinar ruff ,
Using extra dual cuts to accelerate column generation, IN-FORMS Journal on Computing, vol.17, issue.2, pp.175-182, 2005. ,
Solving binary cutting stock problems by column generation and branch-and-bound, Computational optimization and applications, vol.3, issue.2, pp.111-130, 1994. ,
Reformulation and Decomposition of Integer Programs, 50 Years of Integer Programming 1958-2008, pp.431-502, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00392254
Heuristics for the integer one-dimensional cutting stock problem: A computational study, OR Spektrum, vol.18, issue.3, pp.131-144, 1996. ,
A New Branch-and-Price-and-Cut Algorithm for One-Dimensional Bin-Packing Problems, INFORMS Journal on Computing, vol.32, issue.2, pp.428-443, 2020. ,
A branch-and-price algorithm for the two-dimensional vector packing problem, European Journal of Operational Research, vol.281, issue.1, pp.25-35, 2020. ,
