M. P. Cutter and R. Manduchi, Towards Mobile OCR, Proceedings of the 2015 ACM Symposium on Document Engineering - DocEng '15, 2015.
A. Ulges, C. H. Lampert, and T. Breuel, Document capture using stereo vision, Proceedings of the 2004 ACM symposium on Document engineering - DocEng '04, 2004.
A. Yamashita, A. Kawarago, T. Kaneko, and K. T. Miura, Shape reconstruction and image restoration for non-flat surfaces of documents with a stereo vision system, Proceedings of the 17th International Conference on Pattern Recognition, 2004. ICPR 2004., 2004.
E. Lilienblum and B. Michaelis, Book Scanner Dewarping with Weak 3d Measurements and a Simplified Surface Model, Discrete Geometry for Computer Imagery, vol.4992, pp.529-540
K. B. Chua, L. Zhang, Y. Zhang, and C. L. Tan, A fast and stable approach for restoration of warped document images, Eighth International Conference on Document Analysis and Recognition (ICDAR'05), 2005.
H. Cao, X. Ding, and C. Liu, A cylindrical surface model to rectify the bound document image, ICCV, 2003.
B. S. Kim, H. I. Koo, and N. I. Cho, Document dewarping via text-line based optimization, Pattern Recognition, vol.48, issue.11, pp.3600-3614, 2015.
T. Kil, W. Seo, H. I. Koo, and N. I. Cho, Robust Document Image Dewarping Method Using Text-Lines and Line Segments, 2017 14th IAPR International Conference on Document Analysis and Recognition (ICDAR), 2017.
J. Liang, D. Dementhon, and D. S. Doermann, Geometric Rectification of Camera-Captured Document Images, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.30, issue.4, pp.591-605, 2008.
Y. Tian and S. G. Narasimhan, Rectification and 3D reconstruction of curved document images, CVPR 2011, 2011.
A. Ulges, C. H. Lampert, and T. M. Breuel, Document image dewarping using robust estimation of curled text lines, Eighth International Conference on Document Analysis and Recognition (ICDAR'05), 2005.
N. Stamatopoulos, B. Gatos, I. Pratikakis, and S. J. Perantonis, A Two-Step Dewarping of Camera Document Images, 2008 The Eighth IAPR International Workshop on Document Analysis Systems, 2008.
C. Liu, Y. Zhang, and B. Wang, Restoring camera-captured distorted document images, IJDAR, vol.18, 2015.
H. I. Koo and N. I. Cho, State Estimation in a Document Image and Its Application in Text Block Identification and Text Line Extraction, Computer Vision ? ECCV 2010, pp.421-434, 2010.
K. Ma, Z. Shu, X. Bai, J. Wang, and D. Samaras, DocUNet: Document Image Unwarping via a Stacked U-Net, 2018 IEEE/CVF Conference on Computer Vision and Pattern Recognition, 2018.
S. Das, K. Ma, Z. Shu, D. Samaras, and R. Shilkrot, DewarpNet: Single-Image Document Unwarping With Stacked 3D and 2D Regression Networks, 2019 IEEE/CVF International Conference on Computer Vision (ICCV), 2019.
V. K. Ramanna, S. Bukhari, and A. Dengel, Document image dewarping using deep learning, 7th International Conference on Pattern Recognition Applications and Methods (ICPRAM), 2018.
Y. Takezawa, M. Hasegawa, and S. Tabbone, Camera-captured document image perspective distortion correction using vanishing point detection based on radon transform, 23rd International Conference on Pattern Recognition, ICPR, 2016.
URL : https://hal.archives-ouvertes.fr/hal-02073415
Y. Takezawa, M. Hasegawa, and S. Tabbone, Robust Perspective Rectification of Camera-Captured Document Images, 2017 14th IAPR International Conference on Document Analysis and Recognition (ICDAR), 2017.
URL : https://hal.archives-ouvertes.fr/hal-02965121
R. Grompone-von-gioi, J. Jakubowicz, J. Morel, and G. Randall, LSD: a Line Segment Detector, Image Processing On Line, 2012.
M. Zhai, S. Workman, and N. Jacobs, Detecting vanishing points using global image context in a non-manhattan world, IEEE Conference on Computer Vision and Pattern Recognition (CVPR), 2016.
G. Simon, A. Fond, and M. Berger, A-Contrario Horizon-First Vanishing Point Detection Using Second-Order Grouping Laws, Computer Vision ? ECCV 2018, pp.323-338, 2018.
URL : https://hal.archives-ouvertes.fr/hal-01865251
A. Desolneux, L. Moisan, and J. Morel, From Gestalt Theory to Image Analysis: A Probabilistic Approach, 2007.
URL : https://hal.archives-ouvertes.fr/hal-00259077
Y. Xu, S. Oh, and A. Hoogs, A Minimum Error Vanishing Point Detection Approach for Uncalibrated Monocular Images of Man-Made Environments, 2013 IEEE Conference on Computer Vision and Pattern Recognition, 2013.
S. Bukhari, F. Shafait, and T. Breuel, The IUPR Dataset of Camera-Captured Document Images, Camera-Based Document Analysis and Recognition (CBDAR), vol.7139, 2011.
, An Image Based Performance Evaluation Method for Page Dewarping Algorithms Using SIFT Features, Camera-Based Document Analysis and Recognition (CBDAR), vol.7139, 2011.
, Performance evaluation of curled textline segmentation algorithms on CBDAR 2007 dewarping contest dataset, ICIP, 2010.
X. Chen, R. Jia, and H. Zhang, A new vanishing point detection algorithm based on the hough transform, Third International Joint Conference on Computational Sciences and Optimization, 2010.
