Heuristic and lower bound for a stochastic location-routing problem, European Journal of Operational Research, vol.179, issue.3, pp.940-955, 2007. ,
Multiperiod Location-Routing with Decoupled Time Scales, European Journal of Operational Research, vol.217, issue.2, pp.248-258, 2012. ,
Fix-and-Relax-Coordination for a multi-period location?allocation problem under uncertainty, Computers & Operations Research, vol.40, issue.12, pp.2878-2892, 2013. ,
Distribution network design: New problems and related models, European Journal of Operational Research, vol.165, issue.3, pp.610-624, 2005. ,
An exact algorithm for the vehicle routing problem based on the set partitioning formulation with additional cuts, Mathematical Programming, vol.115, issue.2, pp.351-385, 2007. ,
An Exact Method for the Capacitated Location-Routing Problem, Operations Research, vol.59, issue.5, pp.1284-1296, 2011. ,
A Branch-and-Cut method for the Capacitated Location-Routing Problem, Computers & Operations Research, vol.38, issue.6, pp.931-941, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-02474696
Designing a two-echelon distribution network under demand uncertainty, European Journal of Operational Research, vol.280, issue.1, pp.102-123, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02167587
Partitioning procedures for solving mixed-variables programming problems, Numerische Mathematik, vol.4, issue.1, pp.238-252, 1962. ,
A Metaheuristic for a Two Echelon Location-Routing Problem, Experimental Algorithms, pp.288-301, 2010. ,
The Evolution of Omni-Channel Retailing and its Impact on Supply Chains, Transportation Research Procedia, vol.30, pp.4-13, 2018. ,
Lower and upper bounds for the two-echelon capacitated location-routing problem, Computers & Operations Research, vol.39, issue.12, pp.3185-3199, 2012. ,
A computational comparison of flow formulations for the capacitated location-routing problem, Discrete Optimization, vol.10, issue.4, pp.263-295, 2013. ,
An Exact Algorithm Based on Cut-and-Column Generation for the Capacitated Location-Routing Problem, INFORMS Journal on Computing, vol.26, issue.1, pp.88-102, 2014. ,
A GRASP + ILP-based metaheuristic for the capacitated location-routing problem, Journal of Heuristics, vol.20, issue.1, pp.1-38, 2013. ,
Comparing classical performance measures for a multi-period, two-echelon supply chain network design problem with sizing decisions, Computers & Industrial Engineering, vol.64, issue.1, pp.366-380, 2013. ,
Planning models for freight transportation, European Journal of Operational Research, vol.97, issue.3, pp.409-438, 1997. ,
Advanced freight transportation systems for congested urban areas, Transportation Research Part C: Emerging Technologies, vol.12, issue.2, pp.119-137, 2004. ,
Physical internet enabled hyperconnected city logistics, Transportation Research Procedia, vol.12, pp.383-398, 2016. ,
Modeling demand uncertainty in two-tier city logistics tactical planning, Transportation Science, vol.50, issue.2, pp.559-578, 2016. ,
A survey on two-echelon routing problems, Computers & Operations Research, vol.55, pp.185-199, 2015. ,
Flexible two-echelon location routing problem, European Journal of Operational Research, vol.277, issue.3, pp.1124-1136, 2019. ,
Network and Discrete Location, 1995. ,
A survey of variants and extensions of the location-routing problem, European Journal of Operational Research, vol.241, issue.2, pp.283-308, 2015. ,
A column generation approach for the location-routing problem with time windows, Computers & Operations Research, vol.90, pp.249-263, 2018. ,
Multicommodity Distribution System Design by Benders Decomposition, Management Science, vol.20, issue.5, pp.822-844, 1974. ,
Optimal design of supply chain networks under uncertain transient demand variations, Omega, vol.39, issue.3, pp.254-272, 2011. ,
An adaptive large neighborhood search heuristic for Two-Echelon Vehicle Routing Problems arising in city logistics, Computers & Operations Research, vol.39, issue.12, pp.3215-3228, 2012. ,
Logic-Based Benders Decomposition for Large-Scale Optimization, Springer Optimization and Its Applications, pp.1-26, 2019. ,
A comparative study of heuristics for a two-level routing-location problem, European Journal of Operational Research, vol.5, issue.6, pp.378-387, 1980. ,
Integrating collection-and-delivery points in the strategic design of urban last-mile e-commerce distribution networks, Transportation Research Part E: Logistics and Transportation Review, vol.131, pp.37-67, 2019. ,
Dynamic Facility Location with Generalized Modular Capacities, Transportation Science, vol.49, issue.3, pp.484-499, 2015. ,
Subset-Row Inequalities Applied to the Vehicle-Routing Problem with Time Windows, Operations Research, vol.56, issue.2, pp.497-511, 2008. ,
The Stochastic Multiperiod Location Transportation Problem, Transportation Science, vol.44, issue.2, pp.221-237, 2010. ,
The impact of operations anticipations on the quality of stochastic location-allocation models, Omega, vol.62, pp.19-33, 2016. ,
Facility location models for distribution system design, European Journal of Operational Research, vol.162, issue.1, pp.4-29, 2005. ,
Chapter 4: Heuristics for the Vehicle Routing Problem, Vehicle Routing, pp.87-116, 2014. ,
Dynamic Location-routeing Problems, Journal of the Operational Research Society, vol.40, issue.5, pp.471-482, 1989. ,
A branch and bound algorithm for the capacitated vehicle routing problem, Operations-Research-Spektrum, vol.5, issue.2, pp.77-85, 1983. ,
Models and exact solutions for a class of stochastic location-routing problems, European Journal of Operational Research, vol.39, issue.1, pp.71-78, 1989. ,
Methods for solving combined two level location-routing problems of realistic dimensions, European Journal of Operational Research, vol.12, issue.3, pp.295-301, 1983. ,
Lower bounds and reduction procedures for the bin packing problem, Discrete Applied Mathematics, vol.28, issue.1, pp.59-70, 1990. ,
Facility location and supply chain management ? A review, European Journal of Operational Research, vol.196, issue.2, pp.401-412, 2009. ,
High-Resolution Last-Mile Network Design, City Logistics 3, pp.201-214, 2018. ,
A two-echelon location-routing problem with synchronisation, Journal of the Operational Research Society, pp.1-16, 2019. ,
Location-routing: Issues, models and methods, European Journal of Operational Research, vol.177, issue.2, pp.649-672, 2007. ,
Solving the two-echelon location routing problem by a GRASP reinforced by a learning process and path relinking, European Journal of Operational Research, vol.216, issue.1, pp.113-126, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-02507813
A multi-start iterated local search with tabu list and path relinking for the two-echelon location-routing problem, Engineering Applications of Artificial Intelligence, vol.25, issue.1, pp.56-71, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-02478139
, A Quick Reference to OpenMP, Parallel Programming in OpenMP, pp.211-216, 2001.
Improved branch-cut-and-price for capacitated vehicle routing, Mathematical Programming Computation, vol.9, issue.1, pp.61-100, 2016. ,
The Two-Echelon Capacitated Vehicle Routing Problem: Models and Math-Based Heuristics, Transportation Science, vol.45, issue.3, pp.364-380, 2011. ,
A Generic Exact Solver for Vehicle Routing and Related Problems, Integer Programming and Combinatorial Optimization, vol.11480, pp.354-369, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02178171
Stochastic capacity planning and dynamic network design, International Journal of Production Economics, vol.145, issue.1, pp.139-149, 2013. ,
A survey of recent research on location-routing problems, European Journal of Operational Research, vol.238, issue.1, pp.1-17, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-02479036
A Bucket Graph?Based Labeling Algorithm with Application to Vehicle Routing, Transportation Science, p.2020, 2020. ,
The effect of ignoring routes when locating depots, European Journal of Operational Research, vol.39, issue.2, pp.150-156, 1989. ,
A stochastic programming approach for supply chain network design under uncertainty, European Journal of Operational Research, vol.167, issue.1, pp.96-115, 2005. ,
50th Anniversary Invited Article?City Logistics: Challenges and Opportunities, Transportation Science, vol.50, issue.2, pp.579-590, 2016. ,
Distributed Decision Making, 2003. ,
Large Composite Neighborhoods for the Capacitated Location-Routing Problem, Transportation Science, vol.53, issue.1, pp.301-318, 2019. ,
Supply chain design under uncertainty using sample average approximation and dual decomposition, European Journal of Operational Research, vol.199, issue.2, pp.409-419, 2009. ,
A Variable Neighborhood Search Approach for the Two-Echelon Location-Routing Problem, Evolutionary Computation in Combinatorial Optimization, pp.13-24, 2012. ,
Monte Carlo Sampling Methods, Handbooks in Operations Research and Management Science, vol.10, pp.353-425, 2003. ,
Lectures on Stochastic Programming, 2009. ,
Integrated supply chain design models: a survey and future research directions, Journal of Industrial and Management Optimization, vol.3, issue.1, p.1, 2007. ,
Incorporating inventory and routing costs in strategic location models, European journal of operational research, vol.179, issue.2, pp.372-389, 2007. ,
Establishing a Robust Urban Logistics Network at FEMSA through Stochastic Multi-Echelon Location Routing, City Logistics 2, pp.59-78, 2018. ,
Location-Routing models and methods for Freight Distribution and Infomobility in City Logistics, 2010. ,
Vehicle Routing, Vehicle Routing: Problems, Methods, and Applications. SIAM, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01223571
Bapcod-a generic branch-and-price code, 2018. ,
retailers-closing-5000-stores-this-year, Accessed ,
Enabling Urban Logistics Services atLa Postethrough Multi-Echelon Location-Routing, Transportation Science, vol.50, issue.2, pp.520-540, 2016. ,
A heterogeneous fleet two-echelon capacitated location-routing model for joint delivery arising in city logistics, International Journal of Production Research, vol.56, issue.15, pp.5062-5080, 2017. ,
