LS-CMA-ES: a Second-order algorithm for Covariance Matrix Adaptation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Anne Auger
  • Fonction : Auteur
  • PersonId : 751513
  • IdHAL : anne-auger
Marc Schoenauer
Evolution Strategies, Evolutionary Algorithms based on Gaussian mutation and deterministic selection, are today considered the best choice as far as parameter optimization is concerned. However, there are multiple ways to tune the covariance matrix of the Gaussian mutation. After reviewing the state of the art in covariance matrix adaptation, a new approach is proposed, in which the covariance matrix adaptation method is based on a quadratic approximation of the target function obtained by some Least-Square minimization. A dynamic criterion is designed to detect situations where the approximation is not accurate enough, and original Covariance Matrix Adaptation (CMA) should rather be directly used. The resulting algorithm is experimentally validated on benchmark functions, performing much better than CMA-ES on a large class of problems.
ppsnANM926.pdf (621.63 Ko) Télécharger le fichier
hal-02987505 , version 1 (03-11-2020)
  • HAL Id : hal-02987505 , version 1
Anne Auger, Marc Schoenauer, Nicolas Vanhaecke. LS-CMA-ES: a Second-order algorithm for Covariance Matrix Adaptation. PPSN VIII - 8th International Conference on Parallel Problem Solving from Nature, Sep 2004, Birmingham, United Kingdom. pp.182-191. ⟨hal-02987505⟩
30 Consultations
221 Téléchargements
