Shape Representations and Evolution Schemes - Archive ouverte HAL Access content directly
Conference Papers Year : 1996
The choice of a representation i.e. the definition of the search space, is of vital importance in all Evolutionary Optimization processes. In the context of Topological Optimum Design in Structural Mechanics, this paper investigates possible representations for evolutionary shape design. The goal is the identification of a shape in IR n (n = 2 or n = 3) having optimal mechanical properties. Evolutionary Computation has been demonstrated a valuable tool for TOD problems. However, all past results are based on the straightforward bitstring representation whose complexity increases with that of the underlying Mechanical model. To overcome this dificulty, different representations for shapes are introduced, and compared on the benchmark problem of TOD using various evolutionary schemes. The results are discussed with respect to the different degrees of epistasis of the representations.
schoenauerEP96.pdf (241.59 Ko) Télécharger le fichier
Dates and versions
hal-02987523 , version 1 (03-11-2020)
Identifiers
  • HAL Id : hal-02987523 , version 1
Cite
Marc Schoenauer. Shape Representations and Evolution Schemes. Fifth Annual Conference on Evolutionary Programming, Sep 1996, San Diego, United States. ⟨hal-02987523⟩
32 View
30 Download
Share
