Shape optimization by the homogenization method, Numerische Mathematik, vol.76, issue.1, pp.27-68, 1997. ,
Optimal design for minimum weight and compliance in plane stress using extremal microstructures, European Journal of Mechanics, A/Solids, vol.12, issue.6, pp.839-878, 1993. ,
Evolutionary Algorithms in theory and practice, 1995. ,
Acknowledgments, Fractals Everywhere, pp.XIII-XIV, 1993. ,
Generating optimal topologies in structural design using a homogenization method, Computer Methods in Applied Mechanics and Engineering, vol.71, issue.2, pp.197-224, 1988. ,
Algorithmic Geometry, 1998. ,
Representation and Hidden Bias: Gray vs. Binary Coding for Genetic Algorithms, Machine Learning Proceedings 1988, pp.153-161, 1988. ,
Problems of Shape Optimal Design, Optimization of Distributed Parameter Structures - Volume II, vol.II, pp.1005-1048, 1981. ,
Une th eorie assymptotique des algorithmes g en etiques, Cerf, 1994. ,
Artificial Evolution, Arti cial Evolution { EA95, 1996. ,
URL : https://hal.archives-ouvertes.fr/hal-01502737
Genetic Algorithm-Based Structural Topology Design With Compliance and Topology Simplification Considerations, Journal of Mechanical Design, vol.118, issue.1, pp.89-98, 1996. ,
Genetic Algorithms as an Approach to Configuration and Topology Design, Journal of Mechanical Design, vol.116, issue.4, pp.1005-1012, 1994. ,
Mathematical elasticity, volume I: Three-dimensional elasticity, Acta Applicandae Mathematicae, vol.18, issue.2, pp.190-195, 1990. ,
Geometrische und algebraische Methoden der Physik: Supermannigfaltigkeiten und Virasoro-Algebren, 1994. ,
All egement de platines m etalliques par algorithmes g en etiques, Dejonghe, 1993. ,
Meta-evolutionary programming, [1991] Conference Record of the Twenty-Fifth Asilomar Conference on Signals, Systems & Computers, pp.43-51 ,
Evolutionary Computation, 2005. ,
Phenotypes, genotypes, and operators in evolutionary computation, Proceedings of 1995 IEEE International Conference on Evolutionary Computation ,
Intelligent decision making through a simulation of evolution, Behavioral Science, vol.11, issue.4, pp.253-272, 1966. ,
An Adaptive Plan, Artificial Neural Nets and Genetic Algorithms, pp.331-337, 1993. ,
Automatic mesh generation, application to Finite Element Methods, 1991. ,
Analysis of a part design procedure, Numerische Mathematik, vol.71, issue.4, pp.465-510, 1995. ,
Adaptation in natural and arti cial systems, 1975. ,
Topological Structural Design using Genetic Algorithms, pp.Purdue Uni- versity, 1992. ,
Generating test data for Ada procedures using genetic algorithms, 1st International Conference on Genetic Algorithms in Engineering Systems: Innovations and Applications (GALESIA), pp.184-192, 1995. ,
Algorithmes g en etiques et Optimisation topologique, 1996. ,
Structural topology optimization in linear and nonlinear elasticity using genetic algorithms, Proceedings of the ASME 21st Design Automation Conference, 1995. ,
URL : https://hal.archives-ouvertes.fr/hal-02985724
Genetic operators for two-dimentional shape optimization, Lecture Notes in Computer Science, pp.355-369, 1996. ,
A genetic algorithm with sharing for the detection of 2d primitives in images, Actes de la Conf erence Evolution Arti cielle. Cepadues, Toulouse. Michalewicz, 1992. ,
A Survey of Constraint Handling Techniques in Evolutionary Computation Methods, Evolutionary Programming IV, 1995. ,
Intersections, Computational Geometry, pp.266-322, 1985. ,
The Algorithmic Beauty of Plants, 1990. ,
Equivalence class analysis of genetic algorithms, Complex Systems, vol.5, pp.183-203, 1991. ,
Fitness variance of formae and performance prediction, Foundations of Genetic Algorithms, vol.3, pp.51-72, 1994. ,
Evolutionary Algorithms, Genetic Algorithms in Engineering and Computer Sciences. John Wiley. Schoenauer and Xanthakis, pp.573-580, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00140549
Numerical Optimization of Computer Models, Schwefel, 1981. ,
Optimisation de formes par evolution arti cielle. etude de deux repr esentations, 1995. ,
Evolving virtual creatures, Proceedings of the 21st annual conference on Computer graphics and interactive techniques - SIGGRAPH '94, 1994. ,
The Finite Element Method in Engineering Science, Zienkiewicz, 1977. ,
