Improving computational RNA design by incorporating a prior of human design strategies, 2018. ,
Automated Machine Learning, Proceedings of ICLR 2019, 2019. ,
A deep learning approach to programmable RNA switches, Nature Communications, vol.11, issue.1, p.5057, 2020. ,
Design of multistable RNA molecules, RNA, vol.7, issue.2, pp.254-265, 2001. ,
A weighted sampling algorithm for the design of RNA sequences with targeted secondary structure and nucleotide distribution, Bioinformatics, vol.29, issue.13, pp.i308-i315, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00840260
Computational design of RNAs with complex energy landscapes, Biopolymers, vol.99, pp.n/a-n/a, 2013. ,
RNAblueprint: flexible multiple target nucleic acid sequence design, Bioinformatics, vol.33, issue.18, pp.2850-2858, 2017. ,
Fixed-parameter tractable sampling for RNA design with multiple target structures, BMC Bioinformatics, vol.20, issue.1, p.209, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02112888
Flexible RNA design under structure and sequence constraints using formal languages, Proceedings of the International Conference on Bioinformatics, Computational Biology and Biomedical Informatics - BCB'13, vol.2013, p.229, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00823279
SPARCS: a web server to analyze (un)structured regions in coding RNA sequences, Nucleic Acids Research, vol.41, issue.W1, pp.W480-W485, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00819017
Full Design Automation of Multi-State RNA Devices to Program Gene Expression Using Energy-Based Optimization, PLoS Computational Biology, vol.9, issue.8, p.e1003172, 2013. ,
Design of Artificial Riboswitches as Biosensors, Sensors, vol.17, issue.9, p.1990, 2017. ,
Rfam 13.0: shifting to a genome-centric resource for non-coding RNA families, Nucleic Acids Research, vol.46, issue.D1, pp.D335-D342, 2017. ,
RNA design rules from a massive open laboratory, Proceedings of the National Academy of Sciences, vol.111, issue.6, pp.2122-2127, 2014. ,
Extended shapes for the combinatorial design of RNA sequences, International Journal of Computational Biology and Drug Design, vol.2, issue.4, p.371, 2009. ,
Designing RNA Secondary Structures Is Hard, Journal of Computational Biology, vol.27, issue.3, pp.302-316, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-01991541
A unified setting for sequencing, ranking, and selection algorithms for combinatorial objects, Advances in Mathematics, vol.24, issue.2, pp.281-291, 1977. ,
A statistical sampling algorithm for RNA secondary structure prediction, Nucleic Acids Research, vol.31, issue.24, pp.7280-7301, 2003. ,
Reasoning with Probabilistic and Deterministic Graphical Models: Exact Algorithms, Synthesis Lectures on Artificial Intelligence and Machine Learning, vol.7, issue.3, pp.1-191, 2013. ,
, , 2020.
ViennaRNA Package 2.0, Algorithms for Molecular Biology, vol.6, issue.1, p.26, 2011. ,
The equilibrium partition function and base pair binding probabilities for RNA secondary structure, Biopolymers, vol.29, issue.6-7, pp.1105-1119, 1990. ,
antaRNA: ant colony-based RNA sequence design, Bioinformatics, vol.31, issue.19, pp.3114-3121, 2015. ,
RNA inverse folding using Monte Carlo tree search, BMC Bioinformatics, vol.18, issue.1, p.468, 2017. ,
MODENA: a multi-objective RNA inverse folding, Advances and Applications in Bioinformatics and Chemistry, vol.4, p.1, 2010. ,
Fast folding and comparison of RNA secondary structures, Monatshefte f?r Chemie Chemical Monthly, vol.125, issue.2, pp.167-188, 1994. ,
INFO-RNA--a fast approach to inverse RNA folding, Bioinformatics, vol.22, issue.15, pp.1823-1831, 2006. ,
Nucleic acid sequence design via efficient ensemble defect optimization, Journal of Computational Chemistry, vol.32, issue.3, pp.439-452, 2010. ,
Dynamics in Sequence Space for RNA Secondary Structure Design, Journal of Chemical Theory and Computation, vol.8, issue.10, pp.3663-3670, 2012. ,
Solving the RNA design problem with reinforcement learning, PLOS Computational Biology, vol.14, issue.6, p.e1006176, 2018. ,
