Beeping a maximal independent set, Distributed Computing, vol.26, issue.4, pp.195-208, 2012. ,
Lower bounds for covering times for reversible Markov chains and random walks on graphs, Journal of Theoretical Probability, vol.2, issue.1, pp.91-100, 1989. ,
Space-Optimal Majority in Population Protocols, Proceedings of the Twenty-Ninth Annual ACM-SIAM Symposium on Discrete Algorithms, pp.2221-2239, 2018. ,
Message complexity of population protocols, International Symposium on Distributed Computing, DISC, vol.6, pp.1-6, 2020. ,
Computation in networks of passively mobile finite-state sensors, Distributed Computing, vol.18, issue.4, pp.235-253, 2006. ,
A simple population protocol for fast robust approximate majority, Distributed Computing, vol.21, issue.2, pp.87-102, 2008. ,
The computational power of population protocols, Distributed Computing, vol.20, issue.4, pp.279-304, 2007. ,
Self-stabilizing population protocols, ACM Transactions on Autonomous and Adaptive Systems, vol.3, issue.4, pp.1-28, 2008. ,
MAINTAINING DIGITAL CLOCKS IN STEP, Parallel Processing Letters, vol.01, issue.01, pp.11-18, 1991. ,
Plurality Consensus in the Gossip Model, Proceedings of the Twenty-Sixth Annual ACM-SIAM Symposium on Discrete Algorithms, pp.371-390, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-02002629
Stabilizing Consensus with Many Opinions, Proceedings of the Twenty-Seventh Annual ACM-SIAM Symposium on Discrete Algorithms, pp.620-635, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-02002615
Fast self-stabilizing byzantine tolerant digital clock synchronization, Proceedings of the twenty-seventh ACM symposium on Principles of distributed computing - PODC '08, pp.385-394, 2008. ,
Ignore or Comply?, Proceedings of the ACM Symposium on Principles of Distributed Computing, pp.335-344, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-02002544
Minimizing Message Size in Stochastic Communication Patterns: Fast Self-Stabilizing Protocols with 3 bits, Proceedings of the Twenty-Eighth Annual ACM-SIAM Symposium on Discrete Algorithms, pp.2540-2559, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01447435
Minimizing message size in stochastic communication patterns: fast self-stabilizing protocols with 3 bits, Distributed Computing, vol.32, issue.3, pp.173-191, 2018. ,
Synchronous vs. Asynchronous Unison, Algorithmica, vol.51, issue.1, pp.61-80, 2007. ,
Stabilizing consensus with the power of two choices, Proceedings of the 23rd ACM symposium on Parallelism in algorithms and architectures - SPAA '11, pp.149-158, 2011. ,
Synchronous counting and computational algorithm design, Journal of Computer and System Sciences, vol.82, issue.2, pp.310-332, 2016. ,
On Self-stabilizing Synchronous Actions Despite Byzantine Attacks, Lecture Notes in Computer Science, pp.193-207 ,
Bounds on information exchange for Byzantine agreement, Journal of the ACM, vol.32, issue.1, pp.191-204, 1985. ,
Self-stabilizing clock synchronization in the presence of Byzantine faults, Journal of the ACM, vol.51, issue.5, pp.780-799, 2004. ,
Universal protocols for information dissemination using emergent signals, Proceedings of the 50th Annual ACM SIGACT Symposium on Theory of Computing - STOC 2018, pp.87-99, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01503359
Stone age distributed computing, Proceedings of the 2013 ACM symposium on Principles of distributed computing - PODC '13, pp.137-146, 2013. ,
Breathe before speaking: efficient information dissemination despite noisy, limited and anonymous communication, Distributed Computing, vol.30, issue.5, pp.339-355, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01672280
Time- and Space-Optimal Discrete Clock Synchronization in the Beeping Model, Proceedings of the 32nd ACM Symposium on Parallelism in Algorithms and Architectures, pp.223-233, 2020. ,
Fast Space Optimal Leader Election in Population Protocols, Proceedings of the Twenty-Ninth Annual ACM-SIAM Symposium on Discrete Algorithms, pp.2653-2667, 2018. ,
Nearly-Tight Analysis for 2-Choice and 3-Majority Consensus Dynamics, Proceedings of the 2018 ACM Symposium on Principles of Distributed Computing, pp.305-313, 2018. ,
Stabilizing unison, Information Processing Letters, vol.35, issue.4, pp.171-175, 1990. ,
Randomized rumor spreading, Proceedings 41st Annual Symposium on Foundations of Computer Science, pp.565-574 ,
Gossip-based computation of aggregate information, 44th Annual IEEE Symposium on Foundations of Computer Science, 2003. Proceedings., pp.482-491 ,
Brief Announcement, Proceedings of the 2018 ACM Symposium on Principles of Distributed Computing, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01415072
Near-optimal self-stabilising counting and firing squads, Distributed Computing, vol.32, issue.4, pp.339-360, 2018. ,
Efficient Counting with Optimal Resilience, SIAM Journal on Computing, vol.46, issue.4, pp.1473-1500, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01199803
Interacting Particle Systems, 1985. ,
Synchronization of Pulse-Coupled Biological Oscillators, SIAM Journal on Applied Mathematics, vol.50, issue.6, pp.1645-1662, 1990. ,
