Experimental and theoretical observations on DDT in smooth narrow channels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the Combustion Institute Année : 2020
A combined experimental and theoretical study of deflagration-to-detonation transition (DDT) in smooth narrow channels is presented. Some of the distinguishing features characterizing the late stages of DDT are shown to be qualitatively captured by a simple one-dimensional scalar equation. Inspection of the structure and stability of the traveling wave solutions found in the model, and comparison with experimental observations, suggest a possible mechanism responsible for front acceleration and transition to detonation.
ddtNarrowChannels-JMG_LM_R1.pdf (15.7 Mo) Télécharger le fichier
hal-02989874 , version 1 (05-11-2020)
J. Melguizo-Gavilanes, Yves Ballossier, Luiz Maltez Faria. Experimental and theoretical observations on DDT in smooth narrow channels. Proceedings of the Combustion Institute, 2020, ⟨10.1016/j.proci.2020.07.142⟩. ⟨hal-02989874⟩
70 Consultations
54 Téléchargements
