Beyond the chemical master equation: stochastic chemical kinetics coupled with auxiliary processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS Computational Biology Année : 2021
The chemical master equation and its continuum approximations are indispensable tools in the modeling of chemical reaction networks. These are routinely used to capture complex nonlinear phenomena such as multimodality as well as transient events such as first-passage times, that accurately characterise a plethora of biological and chemical processes. However, some mechanisms, such as heterogeneous cellular growth or phenotypic selection at the population level, cannot be represented by the master equation and thus have been tackled separately. In this work, we propose a unifying framework that augments the chemical master equation to capture such auxiliary dynamics, and we develop and analyse a numerical solver that accurately simulates the system dynamics. We showcase these contributions by casting a diverse array of examples from the literature within this framework, and apply the solver to both match and extend previous studies. Analytical calculations performed for each example validate our numerical results and benchmark the solver implementation.
journal.pcbi.1009214.pdf (2.06 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-02991103 , version 1 (05-11-2020)
hal-02991103 , version 2 (14-09-2021)
Paternité
Davin Lunz, Gregory Batt, Jakob Ruess, Joseph Frédéric Bonnans. Beyond the chemical master equation: stochastic chemical kinetics coupled with auxiliary processes. PLoS Computational Biology, 2021, ⟨10.1371/journal.pcbi.1009214⟩. ⟨hal-02991103v2⟩
431 Consultations
309 Téléchargements
