3D Geological Image Synthesis From 2D Examples Using Generative Adversarial Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Water Année : 2020
Generative Adversarial Networks (GAN) are becoming an alternative to Multiple-point Statistics (MPS) techniques to generate stochastic fields from training images. But a difficulty for all the training image based techniques (including GAN and MPS) is to generate 3D fields when only 2D training data sets are available. In this paper, we introduce a novel approach called Dimension Augmenter GAN (DiAGAN) enabling GANs to generate 3D fields from 2D examples. The method is simple to implement and is based on the introduction of a random cut sampling step between the generator and the discriminator of a standard GAN. Numerical experiments show that the proposed approach provides an efficient solution to this long lasting problem.
hal-02992194 , version 1 (06-11-2020)
Guillaume Coiffier, Philippe Renard, Sylvain Lefebvre. 3D Geological Image Synthesis From 2D Examples Using Generative Adversarial Networks. Frontiers in Water, 2020, 2, ⟨10.3389/frwa.2020.560598⟩. ⟨hal-02992194⟩
113 Consultations
0 Téléchargements
