Integer-grid maps for reliable quad meshing, ACM Transactions on Graphics, vol.32, issue.4, pp.1-12, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00862648
Computing two dimensional cross fields -A PDE approach based on the ginzburg-landau theory, 2017. ,
Mixed-integer quadrangulation, ACM Transactions on Graphics, vol.28, issue.3, pp.1-10, 2009. ,
Quantized global parametrization, ACM Transactions on Graphics, vol.34, issue.6, pp.1-12, 2015. ,
Illustrating smooth surfaces, Proceedings of the 27th annual conference on Computer graphics and interactive techniques - SIGGRAPH '00, pp.517-526, 2000. ,
Globally optimal direction fields, ACM Transactions on Graphics, vol.32, issue.4, pp.1-10, 2013. ,
QuadCover -Surface Parameterization using Branched Coverings, Computer Graphics Forum, 2007. ,
Robust field-aligned global parametrization, ACM Trans. Graph, vol.33, issue.4, 2014. ,
Robust field-aligned global parametrization, ACM Transactions on Graphics, vol.33, issue.4, pp.1-14, 2014. ,
Periodic global parameterization, ACM Trans. Graph, vol.25, pp.1460-1485, 2006. ,
Practical 3d frame field generation, ACM Trans. Graph, vol.35, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01397711
Directional field synthesis, design, and processing, ACM SIGGRAPH 2017 Courses on - SIGGRAPH '17, 2017. ,
Sur un système de courbes orthogonales et homofocales, Annales de la faculté des sciences de Toulouse Mathématiques, vol.4, issue.1, pp.1-7, 1890. ,
