The Fitting of Power Series, Meaning Polynomials, Illustrated on Band-Spectroscopic Data, Technometrics, vol.16, issue.2, pp.147-185, 1974. ,
A Survey of Surface Reconstruction from Point Clouds, Computer Graphics Forum, vol.36, issue.1, pp.301-329, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01348404
A Methodology for Automated Segmentation and Reconstruction of Urban 3-D Buildings from ALS Point Clouds, IEEE Journal of Selected Topics in Applied Earth Observations and Remote Sensing, vol.7, issue.10, pp.4199-4217, 2014. ,
3D building roof reconstruction from point clouds via generative models, Proceedings of the 19th ACM SIGSPATIAL International Conference on Advances in Geographic Information Systems - GIS '11, p.3, 2011. ,
A generative statistical approach to automatic 3D building roof reconstruction from laser scanning data, ISPRS Journal of Photogrammetry and Remote Sensing, vol.79, pp.29-43, 2013. ,
Robust regression using iteratively reweighted least-squares, Communications in Statistics - Theory and Methods, vol.6, issue.9, pp.813-827, 1977. ,
On the limited memory BFGS method for large scale optimization, Mathematical Programming, vol.45, issue.1-3, pp.503-528, 1989. ,
On centroidal voronoi tessellation?energy smoothness and fast computation, ACM Transactions on Graphics, vol.28, issue.4, pp.1-17, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00547936
Graph-based modeling of building roofs, Proceedings of the 12th AGILE Conference on GIScience, p.2, 2009. ,
Multi-scale roof characterization from LiDAR data and aerial orthoimagery: Automatic computation of building photovoltaic capacity, Automation in Construction, vol.109, p.102965, 2020. ,
Échantillonnage pour l'approximation de fonctions sur des maillages, 2012. ,
Fitting polynomial surfaces to triangular meshes with Voronoi squared distance minimization, Engineering with Computers, vol.30, issue.3, pp.289-300, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00763898
Laplacian surface editing, Proceedings of the 2004 Eurographics/ACM SIGGRAPH symposium on Geometry processing - SGP '04, pp.9783905673463-3, 2004. ,
Embedded deformation for shape manipulation, ACM SIGGRAPH 2007 papers on - SIGGRAPH '07, p.3, 2007. ,
URL : %5Curl % 7Bhttps : / / data . strasbourg . eu / explore/dataset/odata3d%5C_lidar/information/%7D cf, p.4, 2016. ,
Building reconstruction using planar faces in very high density height data". In : International Archives of Photogrammetry and Remote Sensing 32.3 ; SECT, vol.2, p.2, 1999. ,
A graph edit dictionary for correcting errors in roof topology graphs reconstructed from point clouds, ISPRS Journal of Photogrammetry and Remote Sensing, vol.93, issue.2, pp.227-242, 2014. ,
