A hybrid-dimensional compositional two-phase flow model in fractured porous media with phase transitions and Fickian diffusion
This paper presents an extension of Discrete Fracture Matrix (DFM) models to com-positional two-phase Darcy flow accounting for phase transitions and Fickian diffusion. The hybrid-dimensional model is based on nonlinear transmission conditions at matrix fracture (mf) interfaces designed to be consistent with the physical processes. They account in particular for the saturation jump induced by the different rock types, for the Fickian diffusion in the fracture width, as well as for the thermodynamical equilibrium formulated by complementary constraints. The model is validated by numerical comparison with a reference equi-dimensional model using a TPFA approximation in space and a fully implicit Euler time integration. It is also compared with the usual approach based on an harmonic averaging of the transmissivities at mf interfaces combined with a two-point upwinding of the mobilities jumping over the mf interfaces. Our approach is shown to provide basically the same accuracy than the equi-dimensional model as opposed to the classical harmonic averaging approach which is shown to exhibit physical inconsistency. It is then applied to simulate the desaturation by suction at the interface between a fractured Callovo-Oxfordian argilite storage rock and a ventilation tunnel with data set provided by Andra.
