New interface
Journal articles
Graph-theoretic Simplification of Quantum Circuits with the ZX-calculus
Abstract : We present a completely new approach to quantum circuit optimisation, based on the ZX-calculus. We first interpret quantum circuits as ZX-diagrams, which provide a flexible, lower-level language for describing quantum computations graphically. Then, using the rules of the ZX-calculus, we give a simplification strategy for ZX-diagrams based on the two graph transformations of local complementation and pivoting and show that the resulting reduced diagram can be transformed back into a quantum circuit. While little is known about extracting circuits from arbitrary ZX-diagrams, we show that the underlying graph of our simplified ZX-diagram always has a graph-theoretic property called generalised flow, which in turn yields a deterministic circuit extraction procedure. For Clifford circuits, this extraction procedure yields a new normal form that is both asymptotically optimal in size and gives a new, smaller upper bound on gate depth for nearest-neighbour architectures. For Clifford+T and more general circuits, our technique enables us to to `see around' gates that obstruct the Clifford structure and produce smaller circuits than naïve `cut-and-resynthesise' methods.
Complete list of metadata
https://hal.inria.fr/hal-02995364
Contributor : Simon Perdrix Connect in order to contact the contributor
Submitted on : Monday, November 9, 2020 - 10:20:10 AM
Last modification on : Friday, November 18, 2022 - 9:27:43 AM
Links full text
Identifiers
Collections
Citation
Ross Duncan, Aleks Kissinger, Simon Perdrix, John van de Wetering. Graph-theoretic Simplification of Quantum Circuits with the ZX-calculus. Quantum, 2020, 4, pp.279. ⟨10.22331/q-2020-06-04-279⟩. ⟨hal-02995364⟩
Share
Metrics
Record views
60
